Mini Sheet Metal Box Pan Folder 3mm - (12 Inch) Capacity
weldup
Tavistock, Devon UK
Hi all, this was last Sundays project.
I've wanted a small heavy duty metal folder for a while. As you have probably seen I made a 30 ton hydraulic press last year, but it is not great for folding tight angles less than 90 Deg. I have considered buying one but most can only bend around 1mm or less of mild steel.
I have recently been looking at other peoples ideas but I really wanted one you could box tab sides as well. The only problem is money...!
So I went through the scrap bin and made this out of some off cuts and an old over engineered gate latch.
The folding teeth are made from 40x10mm bar and provide endless possibilities. There is an adjustable back stop that has approx 15mm of travel, for bending different thicknesses. The top beam is made from 40x20mm channel + 50x40x5 Angle + 8x50mm bar. Underneath the floor is a further piece of 50x40x5 angle for extra strength.
The sides and folder beam are made from 80x10mm bar.
Also I have some ideas for some different tooling options which can replace the 40x10mm bars. (e.g a chamfered edged bar welded to box section cut into 5 or 6 different lengths for tight folds in thin steel).
Maybe they'll be next weekends project.
There is a you tube video of it bending 3mm Mild steel:
I have included of one test photo or a very badly bent 3 sided box which is 2.5mm thick. it was a very quick practice run.
W
weldup
Tavistock, Devon UK
Thin Metal Tooling
So today I have been making the thin metal tooling.
These inserts will bend upto 2mm approx.
W
weldup
Tavistock, Devon UK
No plans sorry, I made it up as I was going along.
Thanks theoldwizard1, I hadn't realised the link wasn't working for youtube.
W
weldup
Tavistock, Devon UK
My first commission using the new folder...
So I was asked by a customer recently to fabricate a custom ash pan for her pot belly stove.
So here is it.
It was folded using the thin metal tools, the M/S in 1.6mm thick (approx 16 Gauge?).
(I know 1.6mm is overkill, but my steel supplier is out of thinner stock, at least it will last a long time )
I think it has worked quite well really, I have never used a professional box pan folder, so its difficult to compare the folds, but it's good enough for me.
alan camby
South of Indianapolis, Indiana
Looks great. I like that brake and all the removable fingers.
I used to have a large 4 foot floor pan brake that would do up to 12 gauge steel.
Ended up getting rid of it because it took up to much space.
Would like to have another brake some day if or when I get a large garage/shop.
I have had in my mind of building a brake that goes in the receiver hitches in the side of my bench.
W
weldup
Tavistock, Devon UK
OMG, I would love a 4 foot floor pan brake, as with you I don't have the space.
We have a small homemade craft business in Devon, England making Fused Glass and Ornamental Metalwork ( www.hotfusioncrafts.com ) and I probably would hardly use it at 4'. Most items I build are under 12".
Plus there is something very rewarding about building your own tools. :D
