AMCguy
Yup, I'm pretty sure of it.
My son and I were working on his car. We had pulled the engine and transmission out earlier in the day. We jacked up the back of the car and supported it with stands in preparation for pulling the rear end. It was now getting kind of late, so we decided to call it a night.
Came out this morning to find the entire contents of the gas tank had emptied through the disconnected fuel hose.
The problem is most of it went into the control cut I made in the floor and this floor sits on 2'' of styrofoam. The saw cut did it's job and there is about 1/16'' wide crack at the bottom. I figure about ten gallons of gas found its way through the crack. I've seen what even a small amount of gas will do to styrofoam in only a few seconds.
I'm afraid I now have a 2'' void under a fairly large area my floor. I crawled around tapping the floor with a hammer and it sounds different in the area of the fuel spill.
I'm somewhat relieved this is not in the vicinity of my lift, but I'm still sick to my stomach as I type this.
