Is anyone using, or considered using a heat pump?
My understanding is, they not only provide heat in the winter, but also provide cool air in the summer.
I live in on the eastern end of Lake Erie, so we get some fairly cold, and hot summers, but what I've read, leaves to me understand that, in the real cold months, that I may need to consider "supplemental" heat. So not sure if this is how I want to go.
As far as what I'm heating, I have a 18 X 36 shop I am framing in, inside of a 36 x 54 Pole barn. The 18x36 will have insulation at R11. I have used a Tyvec style wrap around the perimeter, so the insulation is over that.
I will not have gas feed out there, so the heat will have to be electric.
There is plenty of room between the outside walls, and the framing, so I would have no problems running ducts if I went with something like a heat pump.
Thoughts?
Thoughts?
