Lets see your workbench
CaptainMarvel
Orange County, CA
Thanks! Get the kit at Home Depot - $40
Did you paint the brackets black?
TheClaw
Chicagoland
Duke,
Very nice. I was thinking of something similar for mine only red and galvanized. I like the way that turned out.
Jeff
Ch3No2
Here is mine....
Ch3No2
you must have just moved in; NOBODY's shop is that clean otherwise...
Actually just trying to finish the build...that part of the shop is designed to be an engine assembly room
CH3 - Vey nice but I guess you know 5 boxes of tile ain't gonna be enough!
So I am learning...lol.....more like 30 for the entire project...everything just takes time!
Fyrme
Green country, Oklahoma
Picked up my new work bench(es) today while buying some sand blasting sand from a guy. Who knew I'd stumble upon these. Needs a lot of cleaning and fresh paint but I couldn't argue with the price.
robmack
Toronto, CANADA
Here's my bench.
It's a traditional European cabinetmaker's bench that I bought when I was living in northern Europe in the '90s. I brought it back when I returned to Canada. The bench is solid Birch and as far as I know it is 70-80 years old. I keep the bench in the house because it is used for handwork; all the dirty stationary power tools are in the garage. I've replaced the tail vice jaws and lined the shoulder vice with saddle leather to protect clamped work.
mcmlvif100
Northern Indiana
Very nice. Diebold makes good stuff plus that appears to be a Wilton vise on the far cabinet. Is it a C1? Other? From the photograph, it looks like it's in really good condition. Makes your deal even better.
Bugeyed Earl
Davie, Florida
My workbench (salvaged kitchen cabinets with a plywood top) always seems to be cluttered with various projects, and it's sometimes difficult to get to the bench vise, so I finally decided to make some changes to the layout.
Most of my actual projects are done on a small rolling cart - also an old cabinet of some sort, which was in the garage when I bought my house. I've decided to eliminate the clutter magnet work bench, and upgrade my rolling cart to something more solid. The bench vise will go on a standalone pedestal near my drill press. Here's the old cart/work surface:
I wanted to replace it with something a bit more robust but not much bigger, so that pretty much rules out the consumer grade utility carts. I thought I might start with a two-drawer lateral filing cabinet and add a set of locking casters to it, but then I got a great deal on this Lista box:
Adding the casters brought it up a bit higher than I'd like, but I'll probably get used to it. This is my first encounter with Lista cabinets, I'm really amazed at how solid it is!
mcmlvif100
Northern Indiana
Really nice upgrade.
jeffmoss26
Cleveland, Ohio
IT Guy, audiophile, and a fellow lock picker. Seems we have more and more things in common, (used to live in OH but ran away!) What got you started in picking?
Always been fascinated with how things work, plus working at a couple hardware stores during school and cutting a ton of keys!
Vise-Roy
Virginia
My three workbenches: Left photo is the one I use the most. Top is regular tounge-and-groove oak flooring. Craftsman vise. Next is my woodworking bench. 1-foot ruler laying on it for scale. Made from laminated ash, with a prison-made front vise and a Morgan end vise. Leaning up behind it with the blue paint on it is an auxiliary top I can put on it and held by the two vises for greasy work, painting, etc. Right is an outside workbench with a small Craftsman vise. Made from leftover cedar fence posts. (Didn't want to spend any money on it :)
mf44
Here's my bench.
That's AWESOME! :thumbup::thumbup:
TerryH
Springdale, AR
SWEET JESUS that is an amazing looking workbench .... AWESOME JOB !!!
Did you rout the side panels and doors yourself, or did you order/buy them pre-designed?
Thanks!!! Sorry to be so tardy with my response. Just saw the question. I made the raised panels on my router table using a vertical panel raising bit. Same basic frame and panel construction as the doors. Everything is solid white oak. The end panels are set into dadoes in the frames.
Vise-Roy
Virginia
"prison-made"??
Yep.
I bought it at an antique mall, one of those places that has numerous booths occupied by dealers. I bought it from a booth of a fellow who has bought, restored, and resold old tools for decades. I've bought several of his tools over the years. He died a couple years ago.
The vise is definitely not manufactured. No markings whatsoever anywhere on it. All parts are cut from plate steel or otherwise raw steel, not bought from a manufacturer then put together. The screw has lathe marks still on it. The dealer documented it as being made in the Virginia State Penitentiary workshop by a prisoner with obviously very good machining skills. It is damn well made. I don't know how old it is, but it is in very good condition.
Left picture is top view, center is bottom view, before I attached it to my bench. Weighs 24 lbs.
CaptainMarvel
Orange County, CA
Thanks!!! Sorry to be so tardy with my response. Just saw the question. I made the raised panels on my router table using a vertical panel raisin bit. Same basic frame and panel construction as the doors. Everything is solid white oak. The end panels are set into dadoes in the frames.
EXCELLENT WORK !!! ... That's an (at least) $1000 looking workbench - probably more.
(you know, if you ever advertised your services for making custom workbenches)
:bowdown:
thebreeze2012
Northern Il.
I'd like to thank everyone that posted pics of their workbench! I'm getting ready to make a custom one and the pics have helped me alot to customize one to my needs. I'll post some pics when I'm done.
maxspeed96ct
3/4" plywood top with 2x4s as the base and some paint . Also used a old bathroom vainty bottom for some hidden storage.
Still want to do more wall storage next , and will be getting a vise soon.
Gitzy
Newcastle Australia
Curious to why you think the bench is weak?
The frame is constructed from 30mm x 30mm x 2.5mm SHS fully welded and braced then topped off with 16mm plywood it can hold over half a tonne no problems with minimal flex over a 1800mm span.
The span on the right side looks too long for rigidity.
that bench looks weak..also ur blocking a door
