Lighting - need ideas..show me yours!
rickairmedic
louisville ,Ky
That thing holds 2 standard light bulbs and will never repace Flourescent bulbs for output . I would say if you want to get away from flourescents then go with can lights which you can put regular bulbs into and there are versions meant for spot lights . There are a few garages on here with can lights and they look nice . I would say if its a SHOW garage then can lights if someone is actually planning to use it as a workshop then flourescents is the way to go . I will also say flourescents dont use as much electricity as standard bulbs thus the reason we have CFL's now. I will also say there is no way in heck I would pay $70.00 for that thing even if it does say its a dual turbo.
Rick
XR80David
I have four fixtures in my 300sqft work room each holding eight florescent lights. I went with the "Day Light" type lights. It looks kind of weird but boy are they bright. They seem brighter than day. I have to squint my eyes sometimes when I am in there at night.
XR80David
Oh and just so you know you posted in the wrong section. Nothing against you, just a heads up.:)
D
Distinctive-Garages.com
NJ/Philadelphia region
Rick
The fixture is running two Xenon bulbs each. Granted there is NO information that I can find anywhere on the lumens output of the fixture/bulb combination, but figured for looks/output over each car it would be adequate and if I needed to add other lighting I have the space.
Recommend for me a good Flourescent fixture with cold starting capabilities then since my current set up won't fire up well in the northeast from October to April and sometimes won't turn on at all in the dead of the winter due to ballast type.
D
Can you show some pics of the garage and fixtures???? What was the brand and cost?
03mach1
Cuba, NY
Newbie here....cool site.
I put in Can (Recessed) lights along the workbench side, a few in the middle (above the cars) and some along the other side, I think 12 all together, with 3 switches depending on where I am working. I may put in a couple flouresent for extra lighting if/where needed.
I don;t have the ceiling in yet (As you can see), but used Flake Board and painted it white for the walls, left over kitchen cabinets, painted, Laminate table tops for the workbench, still in progress but very usable. !! :) Slowly getting there!
Engine-Ear
a burnout west of Milwaukee, Wis.
Admittedly, I over-think a lot of stuff...the topic of garage lighting is no exception.
One thing that comes to mind when using fluorescent lighting where finished cars are stored is the UV radiation from them... it is my understanding that incandescent light bulbs put out much less UV radiation than fluorescent lights do, and UV plays hell on everything from paint to soft parts.
What are your thoughts on this?
d110pickup
Canton, Ga.
Look at the T5HO lights that are available. I've bought six of the six lamp fixtures for my 30x40 shop. Here's some info on the ones I got.
http://www.simkar.com/pdfs/ReflectABay.pdf
Take a look at the light output and the temperature range that they operate in. I've seen these fixtures and you literally can't look at it when it's on.
Mike
Iron-Iceberg
A-town
T8s with electronic ballast at Home Depot start down to 0 deg. If its colder than that inside. I'm not going in the shop.
Jononon
I very much doubt it's a significant issue, but, if you're worried, shatterproof tubes like GE covRguard have near zero UV output.
D
Mike
What's the price of that fixture and where did you buy?
last12know
i just put in can lites and they are very bright...they lite the garage up nicely...i even went overkill and put in outlets close to the ceiling in places where i may put a bench if i needed extra lite and i don't think that will be a problem....
last12know
and when i say i just put them up.....the drywall just got hung...like yesterday... its a work in progress...
