I wanted to ensure people are aware that the FE18NA mentioned earlier is a residential Mitsubishi mini-split heat-pump that does use the H2i technology (it sounded like folks posting here thought it was just their commercial systems).
Here is the sales speak on it:
"H2i - The Next Generation in Heat Pump Technology.
The H2i modern outdoor unit gives a new level of performance to Mitsubishi Electric air conditioners, providing the extra heat-generating power it takes to deliver comfort and consistency in extreme climates. H2i units use Mitsubishi Electric's INVERTER-driven scroll compressor technology to achieve the desired room temperature quickly, maintaining it consistently while simultaneously conserving energy. Plus with the integration of Mitsubishi's exclusive H2i flash technology, the MUZ-FE18NA + MSZ-FE18NA Mr. Slim Single Zone Mini Split Hyper Heating Heat Pump System, Wall Mounted, Wireless Remote - 22,500 BTU recovers heat energy that is normally wasted in the flash process at the outdoor coil. This process helps the H2i system overcome issues commonly associated with conventional heat pumps such as decreases in lowside pressure, refrigerant mass flow rate, and operational capacity. As a result the MUZ-FE18NA + MSZ-FE18NA Mr. Slim Single Zone Mini Split Hyper Heating Heat Pump System, Wall Mounted, Wireless Remote - 22,500 BTU delivers 100 percent of rated heating capacity at 5 F and 80 percent at -13 F outdoor ambient temperatures.
H2i heat pumps offer a variety of features designed to take the worry out of temperature control such as automatic restart in the case of power outages and automatic cool/heat changeover. Its long line-length capabilities of up to 245 feet expand application possibilities.
Sometimes cooling spaces such as computer or mechanical rooms and kitchens is necessary even when the temperature is below freezing. Air conditioning down to 0 F outdoor ambient temperature is possible with the addition of a wind baffle. Whether cooling or heating, the H2i gives you the flexibility to temper extreme outdoor temperatures."
There was a good post here earlier to the Service Manual that shows the capacity and efficiency. That is what I read when I decided to buy them for my home and will likely get one for my workshop/barn. Here's my experience....
I purchase two Mitsubishi mini heat-pumps this fall (FE18NA). There are three sizes in this series (9K,12K,18K) and I got two of the 18K size.
I live in Southern NH in an open-plan log cabin. I considered getting a bigger system, but they were not nearly as capable at low temps or as efficient as this line, so I decided to install 2 systems serving the same "open room". An added benefit is that I have redundancy, in case one fails.
Our poorly-insulated cabin is 2800 sqft. These units have kept us at above 70 degrees so far this winter, except once when it was very windy and in the low teens. We're happy to light our wood stove and often do just for the ambiance and "free heat", so we could have had averted other under-capacity days and just not noticed (so do not rely on my case for capacity estimates - have an HVAC pro do the math for you).
Due to their efficiency (heating and cooling), they qualify for the highest NH state rebates and we received $900 x 2 for the installation. Fujitsu has a comparable model but since it is a bit less efficient, our rebate would have been half if we had installed those.
