krisway
I will be using 7/16" OSB for a ceiling in my garage. I noticed one side of the OSB has lines printed for lining up the studs. The opposite side looks like some sort of sealant sprayed on. Is there a right or wrong side to screw up to the ceiling?
Also, how hard will it be trying to catch a 2x4 stud with screws on the edge of a sheet of this 7/16" OSB. Will screws bust through the edge of the OSB? Can the edge be safely drilled for a pilot hole first?
Is there a recommended number of screws that should be used per sheet? The rafters are 2x4's, 24" OC. The Home Depot website says that the 7/16" OSB is supported by 24" on centres, so for that reason I'm NOT using strapping. And each sheet weighs 50lbs.
