tractorsupply jobsmart 26 gallon compressor
CNGsaves
KS and OK
Neighbor has an upright Craftsman which is similar to first TractorSupply link you have listed, and that CM is LOUD . . . . like a screamer!!
I'd be more inclined to go with traditional oil splash compressor if you were going with Tractor Supply with this Campbell Hausfeld that is vertical 30 gallon 2 HP that puts out 5.5 CFM @ 90 psi on 120 volt.
http://www.tractorsupply.com/en/sto...-gallon-(belt-drive)-cast-iron-air-compressor
mrbreezeet1
Moundsville, WV, 15 miles South Of Wheeling WV
http://www.tractorsupply.com/en/store/campbell-hausfeldreg%3B-2-hp-30-gallon-%28belt-drive%29-cast-iron-air-compressor
yeah, plus l think the 1st one l linked to is direct drive, as opposed to belt drive, if I had to change a motor sometime down the road, you could do it.
Are the tanks pretty good on the campbell-hausfeld as long as you keep them drained?
Lowes seems to have the same one, listed at a little more, but says 155 max PSI.
http://www.lowes.com/pd_268707-1126-VT6389_0__?productId=3824207
Pumpman1968
Upstate, NY
Unless your going to use it just to air up a tire or basketball......don't waste your money. 4.0 cfm @ 90psi wont run any air tools. And, as another replier said...........its LOUD!
pipsters
USA
You can run all sorts of air tools on a 26 gallon tank. I have a compressor that is 25 gallons 120v I run impact, die grinder, air ratchet, etc. on it. The common misconception is that you need a pump capable of delivering load CFM to air tools to run them effectively. Maybe if you didn't have a tank...
Pumpman1968
Upstate, NY
And...when the pump starts what happens? You sit there with your tool in your hand......waiting.......and waiting. I can guarantee you will spend more time waiting for the tank to recharge than you will working. Save your money.
Davefr
OR
^^^That's not totally true. It all depends on what tools the OP wants to use.
Low air consumption and low duty cycle tools will work just fine with a small compressor.
(ex: Busting lug nuts loose with an impact gun only takes a couple second burst from the tank. By the time he moves to the next wheel the tank has refilled.)
If the OP want to do high air consumption/high duty cycle tasks like sandblasting, sanding, grinding then he should look for a larger unit.
To say that unit "won't run any air tools" is silly and untrue!! The OP should state what his typical tasks will be.
Pumpman1968
Upstate, NY
True....he can probably break loose a nut/bolt with a 3/8" impact. But if a "short burst" is all that's needed, who needs an impact? Guaranteed...the first time he tries to change a tire and the pump starts in the middle of the 3rd lugnut, he will be thinking "why did I buy this POS?"
Just trying to tell the guy to save his money and buy something decent.
shoot summ
I have a little compressor I just fixed that has a similar head to the link you posted, it isn't nearly as loud as the Craftsman oilless units.
Here is my take on compressors(based on experience).
You can "run" just about any air tool, on just about any compressor. There is a huge difference in "running" a tool, and supplying adequate air to USE the tool. I started with a 33 gallon Craftsman, it was miserable waiting on the compressor to always catch up, was easier to use electric or hand powered tools. I now have a 60 gallon Puma, it provides enough air to USE my tools. The two items I have that stress it are the DA Sander, and my Blast cabinet. When it comes time to replace the compressor I will go even bigger, with more air volume.
So the advice here is buy bigger than you think you need, you will never be disappointed.
Pumpman1968
Upstate, NY
Very true. If you want to just watch the socket spin or just make noise in your garage to impress your neighbors, you can "run" any air tool. For the rest of us, you would probably want to "use" the tool.
mrbreezeet1
Yeah, bigger tank would be nicer I guess, I think I just pretty much run an impact in short bursts for now.
Of course, never know when I might want to run something steady.
I have a 20 gallon tank right now, but the tank developed a pin hole.
It is sort of hard to find a replacement tank at a reasonable cost.
All I really need is a good tank.
I think Granger wants about $300.00.
And something used on CL is a **** shot.
Like this one, it's an old porte cable, it's 10 years old, he wants $50.00, and looking at it, I would not trust it. Same as this other one, he wants $150.00 for a tank and pump. Pump needs work. Could this one really deliver 13.5 at 90 PSI? Central Pneumatic is that an old HF?
http://wheeling.craigslist.org/tls/3654159434.html
http://parkersburg.craigslist.org/tls/3643340177.html
pipsters
USA
On my 25 gal, I can break 15 of 20 lug nuts off my car using a 1/2" Earthquake before the pump cycles. Same impact has easily taken off axle nuts and crank bolts, again no cycling.
I've cut angle iron w/ the 3" cutoff.
I've used an air ratchet and never once had to stop.
I agree about the compressor, it's not that great, but some people (like me) don't have the room, the money, or the reason to buy a 220v 60 gal compressor.
OP check this thread out:
http://www.garagejournal.com/forum/showthread.php?t=138871
mrbreezeet1
I'll read it now.
This one seems to have good reviews, do they let all the bad ones on? IDK?
I did a not so good review of the air and water 5000 watt heater that burned the heating element connector, and they never published it.
Don't know if the stores have it in stock, and it says to try to keep it up right,
all l have is an olds Alero.
Probably won't fit.
I miss my ****** wagon sometimes.
http://www.harborfreight.com/2-hors...ir-compressor-68127-8026.html#pr-header-68127
Pumpman1968
Upstate, NY
I'm just telling ya....he will absolutely be disappointed when he tries to use that compressor from Tractor Supply. I understand the economical reasons for buying one of the cheap ones....but right after he uses it, he will have spent $200.00 on a compressor that's almost useless as a football bat.
TAMPAGT07
Palm Harbor, Fl
The CP is harbor Freight...I can tell you, you will probably need to replace the reed plates and gaskets..(approx $50)...I think brand new they are about $170..
mrbreezeet1
