see answers below -- Thank you!
" a) Why in-ground scissor lift in middle of garage?"
Good question .. I came to the realization that:
(1) I want to use 100% of the floor when the lift is not in use. I didn't want to work around posts.
(2) I don't think I will use the lift more than 1 - 2 times per month and occasionally for those extended times when my car is "out of service" for a week or two.
(3) I wanted maximum room around the perimeter of the vehicle on the lift. Note the four floor anchors around the perimeter of the lift (hard to see in the pics). This will allow me to do some "light" frame/body work ( best to use center of the floor)
(5) I already have 3-car attached garage so not hurting for parking space.
"..b) Walls made of 2x6 or 2x4? "'
2 x 4 construction. I never thought the 2 x 6 could justify the cost increase.
"...c) How will you get stuff up to attic to take advantage of I-beam joists? )
What, I pole-vault from the driveway, wouldn't you ? .. actually the stairs go in the far back-left corner. Should get them soon.
"d) Have you considered adding a dormer in garage roof on left side that would be smaller version of look of the house (ie natural light)? "
I did consider that. At least I put windows in the front and rear gable walls :0. There comes a point in time when the budget just can't keep creaping up and up ... but yes, I did consider that. I guess I could add a dormer down the road somewhere. The loft area is really for storage only not living space .. at least for now.
Thanks!
That's pretty stout-built garage. Sure you're glad to see it coming to life!
Curious about a few items:
Looking good. Keep the pics coming!!
