Concrete Idea for new Construction
JDishong
Prosper, Texas
After reviewing many of the flooring options here on GJ, I'd like to get some feedback specific to new construction garage flooring.
After researching GJ on flooring, I am not convinced epoxy or tile is my best solution and since I'm doing a fresh concrete pour I think there are some better options for us in similar position.... concrete stains and dye's.
My preference is dye since there is very little cost adders to the foundation. The concrete either comes "pre-colored" or powder dye is thrown on the surface during trowel. I will still need to seal the floor but I think I am leaning towards this unless you can help talk me off the ledge ...
Here is the finish I am thinking of (Dark Gray (Carbon w/ SandBlasted finish)
http://www.daviscolors.com/Gallery
Any experience or feedback would be appreciated!
bobscogin
Integral color in the concrete is a lot more durable in the long run. Color treated surfaces don't go very deep, and when chipped or scratched you'll lose the color and the damaged area will show the natural concrete color. It's a consideration if your floor will see heavy duty use.
Bob
ConCretin
Central Maine
The dry 'shake on' products can be tricky to use so you'll want to find an experienced finisher to make sure it's done right. Most are hardeners that increase the durability of the surface as well. They are good products but as Legacy said, you'll still need to seal the surface.
J
JDishong
Prosper, Texas
Thank you for your input. I plan to go by the concrete plant this week. I understand they can pre-mix which provide better color control ... I'll give some feedback.
I doubt this will add any significant cost to the foundation so it seems like one way to "test the waters" to see how it turns out. If I don't like the results, there is always more options.
Thanks for the link "hofiveo"
ConCretin
Central Maine
You might be surprised how expensive integral color will be. Depending on the color you choose it can more than double the cost of the concrete. I'm afraid you'll get sticker shock from the cost of polishing as well. Then you've got your sealer. Sorry but there isn't anything cheap here. I love concrete but decorative floors don't always make sense.
J
JDishong
Prosper, Texas
Thanks for the heads-up ... at $7k - $9k foundation cost, cheap is relative. I'll get back when I get some cost figures ... thanks though.
Fastback
Indy
"Polishing", or grinding a new slab after its hard is not really a necessary evil in this case,you can simply power trowel the floor until it overheats a bit and get a cool look that costs very little.
I keep this coated in a sacrificial layer of sealer and then a floor polish so I can redo it if I paint a car and destroy the look (Again).
Here is the floor when I finally moved in a few years ago.
Here it is covered in serious epoxy primers, base coats and clears!
Here it is after stripping and recoating it much like a janitor does a highschool hallway.
Moved back in.
All-n-all it was a pretty cheap floor for looking so fancy, the only added costs were the red integral color in the mix and a wash out fee for the truck. If your concrete guy does not have or use a power trowel or is not comfortable with one then find a different guy.
J
JDishong
Prosper, Texas
This is something I would consider. - thanks for sharing.
Moved back in.
bobscogin
Yes, integral color is expensive. Depending on the color, it can be almost expensive per cubic yard as the concrete itself. To minimize the cost, we pour all the footings/beams in the foundation first with regular concrete, and then finish the pour with integral color in the "slab" concrete which is usually 4"-6" thick.
Bob
Fastback
Indy
When checking on costs, call the yard yourself and check the prices + washout fee, I'm not saying that it can get marked up...OK, yes I am.
J
JDishong
Prosper, Texas
Concrete plant uses liquid dispense coloring system. Depending on color choice, I was told $15 - $50 per cu yd. cost adder (includes washout fee). Gray color in the $25 per yd range.
My foundation is calculated to take 26 - 27 cu yds therefore would cost about $600 - $700.
This doesn't sound too bad to me considering the foundation cost. I realize there are additional costs for sealing, polishing, etc.
-- thought I would share this info. - John
J
JDishong
Prosper, Texas
that makes alot of sense. I will propose that, thanks
Bob
Bricen18
PA
I am currently thinking colored concrete for my new build. Hoedid u make out
J
JDishong
Prosper, Texas
It added about $700 ($25/ Cu Yd), very reasonable.
I still have to grind/polish the floor .. sorry I don't have a larger floor view..
Bricen18
PA
Did u complete the floor in one pour? If not did you notice any color variations between each pour?
J
JDishong
Prosper, Texas
Yes, in one pour and it took several truck loads ... no noticeable color difference. The color mixing was done at the plant.
