http://www.teenbar.net/showthread.php?1506-magazine-page-teen-homepage-health&p=3256#post3256Do NOT use galvanized in ANY FASHION for natural gas - - - even more especially since it's buried. That line is junk for NG.
Dream up some other use for that buried galvie steel pipe . . . . like:
a) air line from garage back to house
b) conduit that something else could be put inside (ie cable TV, internet, intercom system, etc)
[None of above uses for that buried galvie will kill you when the galvie rusts through . . . . . whereas rust thru of NG would be BIG PROBLEM!!]
Now for the buried natural gas . . . . you absolutely should
re-trench another for
yellow polyethlene plastic pipe in say 1" IPS (iron pipe size - - ie thick wall yellow plastic pipe), that is at least 18 inches underground (or deeper that complies with your state and local code - - some states say 30 inches minimum). Thus, give the gas company a call, or a plumber. On each end of yellow plastic pipe, you'll attach a Riser that transitions the yellow plastic pipe to steel that is L shaped (ie goes from below ground to above ground). These connect with a Stabloch connector. In that new trench, you're also required to have Tracer wire (again yellow in color) that is wrapped around the yellow plastic pipe so later on that gas line can be located.
A quick call you can make to get costs and all the parts you'll need is Groebner & Associates in Kansas City Area (Shawnee, KS). Talk with Joe and he'll give you lowdown on risers, shutoffs, tracer wire, stablock connectors, yellow plastic pipe (it's 55 cents a foot) that you will need.
Do not jerry rig this buried natural gas line . . . .
Do It Right the first time . . . . that's with yellow plastic pipe. It's most SAFE method and cheap.
Use the Garage Journal feature up on black line called SEARCH and put in "buried natural gas" as your keywords. Some other threads that have covered this same buried gas line issue are:
Natural Gas Line - - Cost To Install
http://www.garagejournal.com/forum/showthread.php?t=170881&highlight=buried+natural+gas
Cost To Run Natural Gas Line To Garage
http://www.garagejournal.com/forum/showthread.php?t=181258&highlight=buried+natural+gas
Running A New Underground Natural Gas Line
http://www.garagejournal.com/forum/showthread.php?t=178009&highlight=buried+natural+gas
Anodeless Service Riser?
http://www.garagejournal.com/forum/showthread.php?t=137458&highlight=buried+natural+gas
Run Natural Gas Line Underground
http://www.garagejournal.com/forum/showthread.php?t=32833&highlight=buried+natural+gas
