rasit
What are the chances I will be able to pull 3/4" CSST gastite pipe through a
1-1/2" sweep 90*bend (PVC Sch.40 electric conduit)? I ran 50' of straight conduit with one 90* bend under slab when I built the semi-detached garage in case I ever wanted to run propane for a heater. I originally thought I would only need a 1/2" gas line however after running the calculations for a 65,000 BTU heater I picked up, it turns out 3/4" is required. I am concerned about putting the cash out only to find out it won't be flexible enough to make the last three feet of the pull through the bend. Whatcha think???
