KCarGuy
50 miles outside Chicago, illinois
Re: what did you do in your garage today?
I tore into my Son's 1998 Plymouth Grand Voyager with 122K miles on it.
Hard to start, then when it does...Runs like complete Dog **** for 5-7 minutes.
Very Rich!
Was Cussin' out the Engineers who stuffed this 3.3L in sideways, trying to get to the back 3 plugs. I was told to remove the Manifold and even that was not going well....Until...I decided to check YouTube.
Turns out, if you remove the Hood, Wiper Arms, Plastic Cowl, weather seal and un-bolt the entire cowl...with Wiper assm...It gives you great access to the rear (or other side) of the Motor. (who Knew?)
Anyway, I ordered New Plugs, wires, EGR Valve assm., PVC Valve, Coolant sensor, Manifold Gaskets and a Water Pump (because its leaking bad).
After all this ****...It better run Good!
KCarGuy
last weekend, My daughter brought over her 2006 Hyundia Santa Fe that had a Horrible Grinding Noise.
I took it for an Around the Block test ride and after 3 houses, I wanted to throw it in reverse and go back home....Ugh!
I pulled the passenger side wheels off and crawled under...Only to find a Large Section of Metal laying on top of the rear driveshaft.
I had to Pull, Bend, Pull, Bend, pull, Bend until I was able to remove it.
Hyundia added a pick that goes from rear seat to reat seat and over the driveshaft as a Heat Protection or Stone Protection (???), but it rotted away and fell off.
The Floor is solid, but this crappy sheetmetal didnt like Midwest weather.
Easy Fix....For Now. At least is Quite!
Garage5.9
Maui,Hawaii
http://sphotos-a.**.fbcdn.net/hphotos-ash4/226583_10151413222247459_1726425518_n.jpg
Brought this E450 mini bus in to the shop with a code p0131 (IAT temp input high)
while monitoring the temp with the IDS the temp was reading -40f when it really was ambient temp around 85f. While reving the bus up in gear i noticed it would go from -40f to + 110F. To make a long story short i found a pin that was backed out in a connector and when the motor torqued it would pull back on the pin causing the temp to go -
mrodgers
French fries on salad, PA
Did you find it easy to use?
Did you read any instructions or go through a tutorial or watch a video to learn how to use it? Thanks!
I did watch a quick youtube tutorial. I looked up workbench in sketchup and found a video tutorial of someone doing the Kreg pockethole workbench. From watching about 7 minutes of the tutorial, I studded 3 walls of my garage, drew 2 workbenches, my french cleat wall storage rails I want to do, and drew the shelves. I also found a Rav4 model online to put in the sketch since that is what will be parked in there, a tablesaw, my toolbox I mentioned, and the lawn tractor. Tomorrow (at work while I wait for my hour long equip. cycle) I'll draw some cabinets and stuff I want to hang on the walls. It is pretty simple for drawing dimensional stuff for woodworking or designing benches and cabinets.
DHS
Central FL
Got my chainsaws going. Both needed fuel lines, the old Poulan 1800 need the carb rebuilt and I also had to the clean the oil check valve and out in a new oil line. The other is a newer Craftsman (Poulan), rarely have problems with either. People can say what they want about the Poulans but for me they have been great. The 1800 has to be one of the easiest saws to work on, especially for a top handle saw.
Next thing will be cleaning up after messing with them. A lot of oily sawdust all over the bench that needs cleaned up.
NewShockerGuy
Northern Virginia / DC
I love the color scheme in your garage. I may have to steal it. The poster is quite decent as well. Very nice! :beer:
No worries, copy away! :)
Thanks, everything was done by accident in a way too that's the funny thing.. I'm going to take pictures this weekend and start a thread on the process.
-Nigel
A1an
Tampa, FL
Future repair of this (among a few other things):
https://sphotos-a.**.fbcdn.net/hphotos-prn1/11302_10200762424763371_88344379_n.jpg
Required me drain the tank:
https://sphotos-a.**.fbcdn.net/hphotos-ash4/417751_10200769193852594_789118212_n.jpg
Makeshift drain pan. My pan had a 5 gallon max and I had to think quickly to avoid overflow.
I think this car/gas has been sitting longer than a year and a half. When I poured this into a proper storage container there was some nice liquid varnish at the bottom. What was supposed to be a quick/simple fix is turning into something I don't even want to touch.
mrodgers
Ok, I don't hunt, but I'm thinking of taking it up. See, it's the warmest it's been for quite a long time at a balmy 28° today. I only live 60 miles from Punxsutawney, PA. I'm thinking about taking up groundhog hunting.
Early spring my ***, I want to fix up my freakin garage!
Oh, as for what I did in my garage today. Last night the outside cat looked a bit cold and all covered in snow meowing like crazy, so I let her in the garage. Forgot about her and heard her crying on the other side of the door in the garage this morning. Opened the door, opened the door from the breezeway to outside and she bolted out. She won't use a litterbox in the garage. So, there you go, about the only thing I can do in the garage, today I opened the door.
I might even open it again tomorrow. Where is spring?
1jjpop
Central Iowa
Worked getting my golf cart ready to put back together [had it painted alencia orange] getting ready to drive on the street this summer . Legal to run on street in our town.
NUTTSGT
Northern Central Ohio
Realized the 2 handy boxes I bought a month ago only have 1/2" knocks outs. I need 3/4" knock outs. I didn't pay attention when I bought them. :mad:
Farleyfan
Tennessee
Had to plug a tire today using my old t-handle style plugger.
I was thinking one of those older spring loaded (garage type) pluggers
would be nice, so I googled and the only thing close was the stop n go
gun. Does anybody know who has the spring loaded tool, or if those
are still being sold ?
jjs3788
Mocked up new door panels for the wifes 81 Trans Am, then installed the new garage door opener lights
ahrbrz
Added some more garage '****'. Stop sign, Pirelli light, and Jag logo. More to come this week, then I am finished.
Cheers,
Bruce
JimVonBaden
Northern Virginia
IMHO the T-handle and string plugs are still the best!
http://www.jimvonbaden.com/Tire_Plugging.html
Jim :cool:
Lippyp
Shropshire, UK
Put up the first speaker bracket for my new to me garage sound system. Will get the second one up tomorrow and the speakers, just waiting on the amp to be delivered to me and then I can string it all together.
jeffmoss26
Cleveland, Ohio
Dad and I did a thorough cleaning of the basement on Sunday...nice to find lock pins on the floor that dropped 3 months ago :p
Doug Arthurs
Ontario
Finally got my old (54 model) Colchester Student under full power. Looks scabby. Runs good. I'd like to find a more suitable (smaller) three jaw chuck.
I have a Colchester Student as well. I recently moved it into my shop as well as my Bridgeport. Sure is nice having behind the house.
Duke
Fort Leavenworth, KS
Cheers,
Bruce
Ohhhh man, that MGB is gonna pay the price for life under a E Type. No need for wax when you have oil :thumbup:
ahrbrz
It's OK; the 'E' has diapers!
Cheers,
Bruce
nit2wn
Centreville,Al.
Not in per se but just outside. I purchased some of the new Duplicolor Tire shine that's a paint. Since I had 4 new tires to go on my Lightning to be mounted, I figured I'd give them a coat before hand. The stuff calls for 3 coats and supposedly last 5 times longer than Tire Wet and won't wash off in the rain. Pics for references.
bare new tire
1st coat
3nd coat
This is one of the old tires on the truck. One can coated 4 -18'' tires on both sides with some left over. Stuff is around $9 a can and I bought 4 cans just in case the stuff went fast and it took way more than I figured. We'll see how they look when mounted on trucks original wheels. I've had enough of the chrome ones for a while.
IONH
Central Massachusetts
Why would you do both sides of the tire?
Also, if you sprayed pre-mounting, I think the mount tool may scuff some of it off.
nit2wn
Centreville,Al.
It may, I did both sides since I dropped them off and left them to be mounted. I also did both sides to just experiment and in case the tires weren't put on the exact rim to get the shiny side out. The stuff is new and worst case scenario is I have to redo it. The coating won't last forever anyway, directions say to recoat when necessary to regain the desired look. I have had Tire Wet last for months because the truck isn't driven in the rain. I'm hoping this might last a year sitting in a garage out of the sun. It was $9 and time. The rims were just refinished and cost $512 for the 4, I wasn't ready to risk them getting this on them and somehow messing them up.
tribbles
Las Cruces, NM
Replaced the digitizer on my Motorola Triumph smartphone. I have got to get me one of those magnifying lamps, my eyes can't focus closely anymore.
Goobzilla
Wellington, CO
Modified a Sunpro generic fuel sending unit to work in my 68 Scout tank. All ready to put back in and wire up the new gauge
bob_s2
Westmont, Illinois
A few days ago had to dig out the snowblower that had become buried with stuff. A few days before that we had a little cardboard spray booth set up for pinewood derby cars. My son and I had a blast doing the car. Ended up being quite fast, he placed and got a trophy,much to our surprise. We had the wood around the axles break out, so had to re-build and re-install them last minute. Then it was over-weight so had to adjust the weight. It's amazing how plasticwood and super glue can fix stuff.
Olinrj
Greenfield, WI
Just finished putting the gilson snowblower back together. It feels great to have it running but I couldn't let it really run too long. I doubt the neighbors would have liked me clearinf the driveway at 2:30 in the morning.
mdkingsley
Chickamauga Ga
Worked on my uncles truck some more, 81 F100 with a 68 very rough 302. Whenever I get one thing fixed somthing else is wrong. Today it was the fuel pump spraying fuel through the weep hole. Still trying to get the choke set for an easier start without flooding the engine. Pretty tough since you can only really start it cold once a day. Adjusted the valves pretty close no more severe tapping so thats good. And found out the timing pointer is missing. Still have to check the water pump and alt. one of them is doing some intermittent squeling. All started with Do you think you can get my truck running better and check the trasmission leak!
pentavolvo
Indiana
Swept and the hosed garage floor down. Was gonna bring mustang home but its raining today. Bench prepped 3 remote start units for installs this week
garboui
Southern Ontario
- Oil change on the daily driver.
- Finally fixing(replacing) the broken air filter on the air compressor.
