Re: what did you do in your garage today?
I tore into my Son's 1998 Plymouth Grand Voyager with 122K miles on it.
Hard to start, then when it does...Runs like complete Dog **** for 5-7 minutes.
Very Rich!
Was Cussin' out the Engineers who stuffed this 3.3L in sideways, trying to get to the back 3 plugs. I was told to remove the Manifold and even that was not going well....Until...I decided to check YouTube.
Turns out, if you remove the Hood, Wiper Arms, Plastic Cowl, weather seal and un-bolt the entire cowl...with Wiper assm...It gives you great access to the rear (or other side) of the Motor. (who Knew?)
Anyway, I ordered New Plugs, wires, EGR Valve assm., PVC Valve, Coolant sensor, Manifold Gaskets and a Water Pump (because its leaking bad).
After all this ****...It better run Good!
