Hello again friends,
I picked up this American Scale #75H (pictured below) yesterday. It weighs 60 lbs., has 3.5" jaws, has a jaw depth of 3.5", swivel base and a pivoting stationary jaw. The movement is smooth and straight. The only issues are the surface rust and the jaw pin is stuck. Since I love to research the history of my vintage toys, can anyone answer the following questions?:
1. I know vise price is around $1.00 per lb. However, I felt that the pivoting jaw made it worth more. Do you guys think that $100.00 was too much for it?
2. How old is it?
3. Does anyone have any information about the American Scale Co.?
Thanks in advance.
I have a question for members who have knowledge about pivot jaw vises. I'm putting together a jig to press put the pin. I don't want to risk any damage. Is there any possibility that the pin is threaded?
If I'm successful, I'll post pictures of my jig.
Thanks in advance
How do you guy's find these vises, really slim pickings here in Colorado. That is a great find Mark, I would like to have seen the jaws, are they in good shape. I'd pay a 100 easy.
Kevin
Here's an older Parker fixed base. Don't know how old but model number is 300.
The hub doesn't have the patented tension regulating thing inside and never did so Im thinking the main screw is a replacement . There's also a wierd knub under the slide support . I thought it was a screw at first but it's just solid metal. Kinda wierd.
If you haven't already figured it out you can take the swivel jaw off without removing the pin. There are two pins that run across from one side of the vise to the other. Tap them out and the jaw will come off. If you want pics let me know. I have a different version, but I'm guessing they're built the same way.
I picked up this little vise today on Craigslist for $20. It's not huge, but I think I got a decent deal on it.
Not really... found the pic over at practicalmachinist.com It's an 18th century vise that's currently on display at the Conservatorie National des Arts & Metiers in Paris
Whats wrong with this Prentiss? Everything I've read about this 181 indicates it should have a swivel base. It looks like it is either missing or has a fixed base. Any ideas?
It is a swivel base just a different type. You loosen a special nut on the bottom (looks like its missing in the pic), swivel to desired position and re tighten the nut. Some of the nuts had a little handle on them .
This sux!! Friend knocked it off a little table I had it on. What can ya say!? Oh well.
Thanks The tall stand is actually going to be a grinder stand. The 1755 is just perched there for a photo shoot. They are both VERY heavy and i haven't concreted the bases yet. See red quotes regarding the chicom. Yes I bought it new. It was all I could afford at the time and I needed one fast. It's done it's job well, I can't complain.That's a nice upgrade for you Fyrme, and I like your vise stands!
Your "old" Wilton is the Chi-com version (sure you know that already), and the "new" one is the real Made In USA deal - awesome! Good luck finding an end cap - shouldn't be too hard...
Dave
I finally feel like I picked up a vise today worthy of posting here. I've been on the hunt for quite some time. When I bought it I didn't recognize it because it was missing the end cap and had no name stamped on it. All I knew was it was made in USA and it was in good over all condition. Once home, I ran some numbers and realized it was a Wilton 1755. Awesome! If anyone has a good source to find a end cap and a new Wilton tag, I plan on giving this one a proper resto and mounting it on my bench with soft jaws. I'll let my 4" Wilton be my beater vise. Any way here are both in all there current glory.
This^^^ that plate gets attached to the bench top and 1 or 2 lugs on the bottom of the vise engage he notches in the plate the big screw gets a giant wing nut to "lock" it down...
But I don't think there are any lugs on the bottom of the vise..are there supposed to be?
Anyone have pictures actually showing the bottom of a vise like this?
I have seen a large Rock Island vise like this...it DID NOT have any lugs on the bottom of the vise.
And yes the giant wing nut is missing.
Trust me its there...
. The dynamic jaw is a little tweaked (about 3/8 inch) from the static jaw, not sure why, it functions fine and there's no play in the jaws that I can feel, almost like it was made a little off at the factory. .
Fyrme, I really like the direction those Vise stands are going!the Bigger pipe really makes it work! You can even put the lug nut holes to use holding tongs or other tools...
I went to a guys garage to look at a parker he had for sale @ $30 and in the process he says "hey i've got another smaller one...you want it too? $20." needless to say i have both now. Here is the Resto. on the small one. A 1946 Wilton 4" (i nickel plated the handles so they won't rust again... hopefully)
