Ratcheting Box Wrench - Flex
mobiledynamics
Gotham City
So I'm looking to add a set of Flex Ratcheting Wrenches to my stash.
I think for the Flex application/usage, I'm thinking longer might would be the norm....aka. GW XL.
Where do you guys find yourselves reaching for the flex...and what reach are you guys needing the most.
truckwrench1
miami,ok
Malcom extra long spline drive are awesome use them everyday but they are pricey $400.00. Couple guys in the shop just bought the e z red version and the seem to be holding up good also and half the price
cookefab
Just south of Hell, SW Va
I see no point in owning any ratcheting wrench w/out[/B a flex box end. Not even the best ratcheting wrench should be used to break loose a fastener, so why have redundancy?
FWIW, the Matco school of thought is break loose w/ the open end, then flip to the ratcheting box end to run the fastener off...absurd, says me...
Chadwilliam1
Cincinnati
I have given my craftsman ratcheting wrenches everything I have and never broke a single one. I have double wrenched them and kicked them and they work great. So I do use ratchet wrenches to break loose and tighten things.
Chuck122
Québec, Canada
I got the MAC EDGE flex head ratcheting wrenches. One of the really nice application IS when removing doors. They are really great all around wrenches and are very conveniant. I LOVE them. They are 6 points. I may warn that they are not stamped USA, if this IS a concern to you. I can assure you that the ratchet is no gearwrench. Il has much less slop and feels much more solid. The open end is also much nicer than the gearwrenches. This may sound like some sale pitch but really they ARE great.
6-Holer
A couple of years ago I got an extra-long metric set with S-K's name on them. I'm sure they're the same ones that now are sold by E-Z Red. I bought mine almost immediately after first seeing a friend's sets. He had both English & metric versions. I could tell that they were too good an idea to pass up. They make being around the timing-end of nearly any transverse-engined car almost a pleasure. These were my first ratcheting-box-ends, other than my ancient, laminated, 17-21mm, air-cooled VW one of course. In my opinion, if you don't have any ratcheting box-ends yet, a set of these extra-long ones won't be a good trial for seeing if you're a ratcheting-box-end kind'a guy......they're so long you'll only grab them when you need the length. In my experience, their extreme length gets in the way of 'ordinary' end-wrench use. But be honest, when has a little extra length of anything been a real problem?
06 DIESEL
Middle River, MD
I have almost every style of ratcheting wrench that is made, and I reach for my crossflex or flex before any of the others. They all have their advantages in certain situations and there has been times I was glad I had a particular style as it made the task at hand so much easier.
cgv69
Boone Co., KY
SK used to sell what I think would be perfect - Their G-Pro series 5 Piece XXL Double Box Flexible Reversible set # SKT89650
Extra long, flex head, reversible and spline drive. Everything you could want IMO. Only down side is they were not US made so when Ideal bought SK, they dropped all of their non-USA products and now these are no longer available.
I believe these were made by EZ-Red (or whoever makes EZ-Red's wrenches?) but unfortunately I don't think EZ-Red sells a version that has both a flex head and a reversible ratcheting mechanism anymore?
glenmore
Los Angeles
I think the prices on these things just jumped up about $20.
The set EZRRM6 used to run around $135-$140 now the only sellers are at $160.
Rezeppa
Newport, MI
Have these wrenches if he is referring to flexhead in both metric and standard. I researched just like you are and found them to be hands down the best. I use these things to break loose bolts with, I have double wrenched them and not broken one yet. When I bought them they were the only 6 point ratchet wrench available. I have the opinion that all ratchet wrenches should all be 6 point. I also have craftsman not flex USA ratchet wrenches and they don't hold a flame to the quality. Idk the COO most likely Taiwan but they are still quality you can find used on eBay for around 150-200 a set.
Skin
Boston
In the real world ratcheting ends are used to break fasteners loose all the time. Shouldn't be done, but it is done. Not sure what dated info you're going by but Matco fully supports breaking loose fasteners with their ratcheting box ends. They even went so far to make this silly vid touting the strength of the ratcheting mechanisms and even though it isn't stated, considering all 13mm wrenches took well over 100 foot pounds, in my opinion, there should be no hesitation to use them to bust something loose.
Flex **** when you're trying to snake the wrench someplace where you cant fit your hand since you generally need to support them with some pressure to stop the flex end from flexing as you try and fit it on. Especially frustrating in rusty areas where fasteners grow substantial rust scale which means any box end or socket needs to be persuaded on. This can be done at length with a fixed end, but not a flex.
Flex have their place but if they were my only set of ratcheting wrenches i'd probably of torn my hair out from frustration long ago.
cookefab
My "dated" info is straight off Matco's website, specifically the GRCL series, which are not flex...suffice to say that I'm old, (40 - maybe not so much) and set in my ways. If this is just a good natured debate, then I'll partially agree when it comes to breaking loose small fasteners - <12mm, maybe, depending on torque, quality, or lack thereof, of the wrench, etc...
On the flip side, would you take one of the Blue Point, 'nese made, expanded size ratcheting wrenches, say the 21mm and put your *** behind it against...a 10 year old Jeep control arm bolt/nut? Me? I find plenty of creative ways to f**k myself up on any given day...I'll gladly break out an "old school" combo for the break...
