joelowrider
we are building a new home now and I am going to have a brand new concrete floor what would you recommend for it I will park in it most days and work on cars ect a lot in it
Your floor looks nice. So that color was mixed with the concrete when poured?Everyone will recomend what they have, so I would suggest that you be honest about what kind of work you will be doing.
If its a garage to showcase toys and a detail shop then you can pick anything.
If you are going to deal with a lot of oily bits and do motor work epoxy is nice, but spendy.
If you weld a lot or paint then I would not use a "flooring" product at all and look into staining the slab if it's already poured.
If its not poured yet you can have the concrete guy use intergral color in the mix and trowel it into a nice slick surface. This way you turn the actual floor into flooring that is as durable as concrete.
Here is a post from last week.
http://garagejournal.com/forum/showpost.php?p=2951865&postcount=11
Porcelain tile. Check out the 12 Gauge Garage thread.
