3 Phase Motor Wiring
Right Angle
I recently acquired a metal lathe from my uncle. It's an early 80's Jet. It sat unused in his garage for 20+ years. It currently has a 3 phase motor that was wired in the low voltage wye configuration.
I have 3 phase power, but after hooking it up, it turns really slowly. Unfortunately, the plate is completely worn off except for the stamped values. I am wondering if this is not a dual voltage motor and is only set up for 460. Is there any way to determine if this is a 230/460 motor?
Thanks in advance for any help.
Gooch
Petersberg, IA
how many leads are in the peckerhead? 3=single voltage, 9=dual voltage.
wyliesdiesels
Modesto, CA
What type of 3-phase service do u have- wye(208v) or delta(240v)?
R
Right Angle
There are 9.
It looks like there's two amp figures on the right side, so dual voltage.
Yup, where it says 2.8/1.4.
That's kind of what I was thinking.
I believe it is a high leg delta.
If it is a dual voltage motor, any ideas on why it's running so slow?
Norcal
Check the leads if it's wired for 460V, that is very likely the problem, & it's better then being supplied w/ 480V & wired for 230V. :(
R
Right Angle
I'm almost positive it's wired for low voltage. Currently it's: L1=1&7, L2=2&8, L3=3&9, and 4,5, and 6 are wired together.
sparky36000
North Dakota
Yeah, that's the low voltage connection..........how does it sound when it's running? Loud growling and low torque? Can you put a clamp ammeter on the leads and see if it''s close to the 2.8amp rating? Curious to see what you find out.
R
Right Angle
I didn't let it run for more than a couple of seconds. It sounds similar to a motor that's starting up, a low constant hum.
I was thinking about using an ammeter after I reconnected everything.
OccupantRJ
Eastern North Carolina
Check the bearings and motor shaft. i have seen shafts wear inside bearings, and worn bearings that would let a rotor get off center a tiny amount, which can cause drag. Replacing the bearings or repairing the shaft took care of things.
R
Right Angle
After deciding that everything looked proper, I wired the motor back up to test the leads with an ammeter. A funny thing happened, the motor seemed to spin at the proper speed.
I'm not sure if I was just mistaken originally when I thought the motor was spinning slowly, or if something changed. I'm thinking it was the former.
As an aside, each of the three feeds showed roughly 1.6 amps while running. I'm assuming these don't simply sum for total draw. What's the correct math to determine the draw?
Thanks for everyone who chimed in to help.
sparky36000
North Dakota
The amp on the nameplate is per leg you don't add them together. The 2.8amps is also full load amps, with no load on the machine it will be less. Sounds like your good to go.
StayThirsty
any chance you bumped the speed knob between having it on and off? I was going to say it sounded like you lost a leg and was "single phasing" if you had a fused disc. Sounds like you got it figured out though. Watch out for the ol ******* leg!
wyliesdiesels
Modesto, CA
The high/stinger leg, aka what ur calling the ******* leg, is only of concern with single phase 120v loads!
