Some installations slope the main line away from the compressor so that the moisture flows with the air flow towards a drain leg at the end of the line. In some installations the end of the line is sufficiently close to the compressor that an automatic drain valve can be used otherwise the drain leg must be drained manually.
Automatic drains are nice, as long as you drain the end of line filters by hand.
Heres what happened to me. At the end of the day I always drain the filters (water traps).
I drained them and (they have little wingnuts on the bottom) and after I tightened the wing nuts back up, I noticed my finger tips felt slippery, did the sniff test and figured something let loose in the compressor pump.
If I would have had an automatic drain, I probably would have saturated my air lines pretty good. I bought another compressor, This is the third compressor in I guess 12 years.
The first one went 10 years and the second two years now I have the third one. I buy the $750.00 plus tax type, 2 stage pump up to 175 lbs.
I know I should have sprung for a good one for around $1500.00 in the first place.
These $750.00 compressors will run a 100 lb pressurized sand blaster pot, or any air tool with out a problem, also I guess I could mention that I had a black max, then ingersol ram, 10 years on the black max, 2 years on IR, now I have a porter cable, but all three pumps look identical.
I'm also a hobbist, although I use them quite often, you would think they would have lasted longer, I changed the oil with regular compressor oil like they called for, even change the oil and filter more frequently then they call for.
Rob
http://www.1969supersport.com
