Does anybody have any experience with any of the Hole Saw kits from Harbor Freight?
When you guys return tools does it require a receipt?
portable blower. any of you guys have this?
http://www.harborfreight.com/portable-blower-with-variable-speed-dial-93231.html
I have this and used it all last summer. Throws a lot of wind for the price. By design it is directional so you'll want it kinda pointed at you or it.
Also used it on a photoshoot pointed at the model. Nice and quite for that kind of use.
Think i got for $35.
I have the bimetal set, works surprisingly well.
http://www.harborfreight.com/18-piece-carbon-steel-hole-saw-set-68115.html
It's nothing to write home about, but it will cut holes. I bought it for installing recessed lighting in drywall, but I've used it for wood and other things and it will work. Take your time, and clean the teeth often. If this is something you'll use often, I'd recommend upgrading to something else. 3.5/5 for me.
Anyone have the 14" chop saw? Item# 68104. Seems to have pretty good reviews. Definetely cheap enough. Works out to be $80 with the 20% off coupon.
Drillmaster heat gun: EPIC PASS, if you consider catching on fire as the "heat" feature of the product.
I've got both these items. Had the saw for probably 8 or 9 yrs. Completely trimmed out 2 houses with it. Plus dozens of other smaller projects. I have the slider, cuts thru a 4x4 with a descent blade on it.
Recently restored the plastics on my 05 KLR 650... the red plastic had turned pink in the sun. But the heat gun performed without a hitch.
I have been using this for 3 years for all my heat shrink wrap on wiring jobs, never once had an issue or caught something on fire...
That is exactly what I bought it for. I shrank two connectors and then saw smoke coming out of the housing. I unplugged it and flames came out of the vent slots. I'd be willing to try another one. Do you think they'll exchange it after it was blasted with a fire extinguisher?![]()
Thanks but it was actually the metal cutting abrasive saw that I was asking about.
the ones i had were horrible. all wobbled, drilled wrong. threw them out, but that was about eight years ago
1/2 Impact Sockets- Pass
3 pc 1/2, 3/8, 1/4 socket organizers-Pass
Yellow Plastic Trim removing tools- Pass so far, really handy
Impact Driver- Fail, shattered on the first hit trying to loosen a rotor screw
1/2 and 3/8 Swivel Sockets- Fail, snapped the pin when removing wheel bearing hub bolts
Love this thread.
The yellow plastic trim tools **** if you use them more than twice. All of them in the set have cracked and broken. Now I used them like once a day so I don't know if that's past their use rate. Maybe they have made them better in the past couple years.
Light blue nitrile gloves used to be a major PASS, now they're a borderline FAIL. For the past six months to a year, they've been much thinner and easier to tear. For minor clean ups, etc. the light blues are still okay, but I used to use them for car repairs, moving around old and/or greasy equipment, etc. but they self-destruct too easily nowadays.
I get the blue ones from Costco and they tear somewhat easily also. but the black HF ones are a little more heavy duty. Not so much that I'd go after them only, usually i wear either underneath real gloves when i can. 90913 gloves work pretty well for 'longer term' disposables.
Went and picked up a wrench rack for my Cman RP wrenches and I give them a Fail. Unfortunately the wrenches will not stay put, and "snap" out of place. You can get them to stay, but all they do is slide from left to right. Perhaps it could just be a bad set I purchased.
In the past few years, I gave up on HF gloves.
Kimberly-Clark Professional Kleenguard have been good to me, in grey. I wore a pair and had them off and on a half dozen times yesterday & a couple more today; still kicking.
They are worth the difference in cost easily.
I got sick of changing out the drill bit for a philips bit. I stopped into HF to pick up a cordless screwdriver. It is a gun style 4.7 volt unit. I was looking for a stronger unit but they don't have one.
I purchased it and unless you are using it to hang and remove short screws off switch plates please save your money.
I had been using my williams ratcheting screw driver but the screws I was removing were 4 inches long and on toggle bolts in the wall. Drill was much more efficient.
Looking for a better cordless screw driver-Any suggestions.
wow you can use a pair of nitrile gloves more than once ...... if i have them on more than 10 min. there dripping wet one time wear for me ....
