RedAggie03
I've had issues with my arc fault breakers in my new home since the day we moved in. The builder has been great and has had his electricians out a number of times troubleshooting the issue. The issue occurs in the upstairs and downstairs living rooms mostly.
Here is what has been done so far:
Long story short, I've narrowed it down to my plasma TV's. If I put NOTHING connected it seems to stay solid. If I turn on the TV / Roku it will play for a while and trip. I read some on the internet and some say that surge protectors can cause it, but it will trip with it plugged directly in. I put the TV on an extension cord and plugged it into the bedroom plug (never has tripped) and it tripped it after a few hours. Never right away. I also tried a TrippLite 4 plug surge box with a RFI filter which I read worked for treadmills. No luck, still tripped. I does seem to stay on longer if I plug the tv into a heavy duty 25' extension cord. I thought it fixed it for a while, but it finally tripped today after having the tv on most of the day. ugh.
So I really don't want to replace both of my TV's to fix the issue, but is there something else I can do???? Are AFCI's required in the living room? I know I can replace it with a regular breaker, but it won't be to code I don't believe. What else could I do?
- checked ground to the box
- checked feeds / ground lugs in the breaker box
- replaced AFCI's (twice now)
- pulled every plug, switch, and fixture and tested / rewired
- pulled all can lights and checked for correct wiring / pinched wires
