Torque1st
MEMBER EMERITUS
CPVC carries the same manufacturer warnings as PVC.
As an example from:
http://www.spearsmfg.com/prod_brochures/80C-2-0406_1108_web.pdf
When you look you will find that even LOW pressure testing is not recommended.
Just use the right stuff and don't take chances with the lives of those around you.
As an example from:
NOT FOR USE WITH
COMPRESSED AIR OR GASES
Spears® Manufacturing Company DOES NOT
RECOMMEND the use of thermoplastic
piping products for systems to transport or
store compressed air or gases, or the testing of
thermoplastic piping systems with compressed
air or gases in above and below ground locations.
The use of our product in compressed air or
gas systems automatically voids any warranty
for such products, and its use against our
recommendation is entirely the responsibility
and liability of the installer.
WARNING: DO NOT USE COMPRESSED AIR OR GAS TO TEST ANY PVC OR CPVC THERMOPLASTIC PIPING PRODUCT OR SYSTEM, AND DO NOT USE DEVICES PROPELLED BY COMPRESSED AIR OR GAS TO CLEAR SYSTEMS. THESE PRACTICES MAY RESULT IN EXPLOSIVE FRAGMENTATION OF SYSTEM PIPING COMPONENTS CAUSING SERIOUS OR FATAL BODILY INJURY
