Attach 2-2-2-4 to breaker panel?
tankd0g
Nova Scotia
Can any tell me what you need to attach 2 and 4 AWG wire to a breaker panel? the 40A breaker in the panel will not take wire that thick and I doubt it's rated for aluminum anyway. I assume there is some sort of intermediate junction box you can use?
Falcon67
Merkel, TX
You could pull to a 6x6 located next to the panel and splice out of that. A 60 or 70A breaker that will take that wire is a whopping $40 at Home Depot, which may not apply in your location. By the time you do all the wig-wag to splice 2-2-2-4 to 6 or something, conduit, fittings, etc, etc you could just have a breaker and be on to the next project.
T
tankd0g
Nova Scotia
The problem is that my panel is obsolete Canadian ITE Blue Line and I can't find a 60 or 70A for it, if one ever even existed. Home depot has a compatible 40A for $90, but that's it. I don't want to tear the house panel out just yet but I will need some kind of power in the garage for now. I assumed there was some kind of terminal block I could buy with suitable lugs but I haven't found anything.
madosta
Eh... you could look at polaris taps, but they are expensive and should accommodate different size wires.
I would make sure you leave enough wire for your new panel though.
Norcal
The use of a 6X6 box as suggested earlier is like trying to stuff 25 pounds of **** in a 5 pound bag, undersizing a box is about one of the worst things to do, but when dealing w/ a loadcenter (centre in Britspeak :D) that is obsolete, a J-box & Polaris connectors or split bolts to reduce the wire size may be the only choice other then change out the panel.
T
tankd0g
Nova Scotia
I have a 12x12 and some connectors, I'll have to see if I can find these Polaris connectors anywhere. I'd still rather have a rigid terminal block but I guess it's only temporary anyway.
pattenp
Virginia - USA
If you have space in the panel you can do the splice in the panel using a short stub piece of wire to fit the 40 and use splice/reducer for the splice. Tape up the splice well.
T
tankd0g
Nova Scotia
I guess alternatively I could leave my house panel in place, split the 00 wire coming off my meter into a panel and split it 100A/60A or 100/100. I'd have to get the meter pulled for that of course. Has anyone seen a box that would provide a 200A shutoff and split the feed two ways without buying a full load center and breakers?
Falcon67
Merkel, TX
That would work - or IF your utility allows for double tapping the meter, just double tap out to a 100A box and terminate the shop feed there. That's what this is, comes right out of the meter can. Utiltiy installed too.
T
tankd0g
Nova Scotia
Do you know if they just doubled up on the conductors in the lugs on the meter base or were there two sets of lugs? I know on my panel the 00 wire is so thick it barely fits in the lugs, so there's no room for another wire, otherwise I would probably just go off that, I'm not sure what it looks like on the meter side.
Falcon67
Merkel, TX
They doubled. I didn't get a pic of the meter side but a 200A meter has pretty big lugs. We're on a co-op. We pay a bit more, but they are a friendly bunch. The cost of the above was zero $ and he pulled the box out of the truck.
