The problem with those quick aluminum setups is making modifications, extensions, or fixing leaks a few years from now when the company that made them has gone out of business. Many businesses fail and many more will fail over the next few years. Iron pipe and fittings will be available for our lifetimes.
I think if there is a fire in my garage hot enough to melt the air lines and fittings, a few hundred dollars worth of aluminum and plastic is the least of my worries...
You dont follow, as usual.
Why would you even think of relying on 0-rings, when a threaded/sweat-soldered connection is so damn bullet-proof?
And you do know that there are MANY grades of O-rings, right?![]()
It could make the difference in the fire department getting there in time to save your lives, the house, and part of your tools versus not saving anyone or anything.
Hows that? Please explain...
Bullet-proof, my ***. I fixed about 10 gas leaks at the house today, and have about another 15 joints to fix in the morning.
I tried plumbing my air compressor with Lowe's fittings, fat ******* chance. I tried pipe dope, pipe tape, pipe tape and pipe dope, waiting 24 hours for pressure, none of it worked. I ended up buying high dollar US fittings to get no leaks.
Oh, technically it could. So could waking up 2 seconds earlier, or having your room a foot closer to the exit. In reality, it's splitting hairs, IMHO.
Have any of you ever used a bellows on a fire? The air stream makes things burn very fast and very hot. That is why fire and building codes specify iron pipe. The fire has to be really hot to hurt it. It just gives the fire dept and your family some additional time to save things and the differences were well documented in testing. There are good reasons for those codes.QUOTE]
Correct. If a fire starts to break out in the garage/shop it can burn up the oxygen with in the room but stay in a smoldering state. It can still be hot enough to melt solder though and if there is approx 150# of presure wanting to seperate the copper lines it will aid in it, thus feeding the smoldering fire and then it can take off and spread rapidly.
Never store flamibles close to water heaters, furnesses, or items that create sparks.
Just to make you aware, I am NOT talking about black iron. Did you not read that?
I sure hope you are not running gas in copper.
Either way, it isnt the pipes fault the installer did a half-*** job.
Pipe fittings/joints last a LONG time. I have done propane to natural gas retrofits in homes that have 30+ year old black iron systems in them. More often than not, the system passes a pressure drop test as-is.
So... whats the problem again?
You buy cheap fittings, and Ill assume cheap pre-threaded *******, and you are complaining that they are ****?
No matter really, Ill bet money that it was operator error again. If you were working with steel pipe fittings, Ill bet you simply did not have the fittings tight enough. Pipe threads only seal when TIGHT.
Hardly splitting hairs.
Lets take a specific example, that would apply to 90% of this board.
Say a fire erupts in the garage/shop. Oily rags thrown into a barrel that self-ignite. That fire needs FUEL, the primary one being Oxygen, secondary being that of some sort of combustible material.
A roaring fire runs out of oxygen FAST. You should know this, if you have ever burned wood in an air-tight wood stove.
Get a good fire going, then shut the damper and choke it down.
What happens when you open the door![]()
NFPA rules as well as OSHA rules have been writen due to somone being killed.
You could drive with your seat belt off for the rest of your life and nothing happen to you, but it is a chance you are taking.
...And what do you guys think about running the tube in the walls?? if you plan it out well so no changes would be needed..
... I have seen pvc pipe used but would not recommend it because if there is a pressure failure there could be shrapnal produced which could cause additional injury. ...
... It is true that the "exposed pipe" would 'aid' in the cooling aspect of the compressed air. However this is a very small aspect. Piping in hospitals(breathing air) and other "clean" enviroments is located inside walls/ceilings. If moisture is a problem you should deal with that with a dryer located at the compressor. Otherwise install 'point of use' filter/dryers along with moisture pots. Proper pipe fall should also be adressed.
Hope this helps. You can PM me and I can share other air piping experiences.
66L78, Check to see if the aluminum system is ASME or ASTM tested and to what standards. Compare this to copper and threaded pipe. Remember that there is also welded pipe and pex to through into this discussion. I have seen pvc pipe used but would not recommend it because if there is a pressure failure there could be shrapnal produced which could cause additional injury. What you really want to know: is the piping system suitable for the application and enviroment? Additionally, us must identify the max working pressure of the pipe and if it is air compatable. Some piping systems and corresponding fittings are not.
In my opinion, most garages and small shops only require 3 to 6 drops and cost (unless you are really pinching pennies) between the best(most expensive) and the budget(least expensive) is very small. Only if you are going to change the layout frequently or impress you buddies would it be benefical to go the cadillac route. All of the industrial environments that I was responsible for in the past utilized black iron threaded or welded pipe. Proper piping techniques are required no matter what system you choose. You may want to use a conventional piping system for distribution and then go with the aluminum system for the drops. It is true that the "exposed pipe" would 'aid' in the cooling aspect of the compressed air. However this is a very small aspect. Piping in hospitals(breathing air) and other "clean" enviroments is located inside walls/ceilings. If moisture is a problem you should deal with that with a dryer located at the compressor. Otherwise install 'point of use' filter/dryers along with moisture pots. Proper pipe fall should also be adressed.
Some of the people here need to move forward 100 years or so...........
The factory I'm sitting in right now has literally thousands of feet of copper air line in it. In the 23 years that I've been here I've yet to see a failure in the hard line portion of the air system.
Black iron is simply a PIA and expensive to work with. Threading machine?? Yep, I've got 2 or 3 of those in my shop just waiting for the next time I need one. Tried to buy a decent pipe theading setup lately?? Prepare to spend some big dollars for one that does a better job of threading than the Chinese do.
Ever look inside any new production equipment, CNCs, tractor trailers??? Wanna guess what they use for air lines?? It ain't black iron, and it's all sealed with push-fit O-ring'd connectors. Again, rarely see a failure.
Compressed air fanning the flames?? I'll bet you've got the pressure relief valve on your tank plumbed outside don't you?? What happens when a fire starts near the compressor, flames heat the tank, the air pressure goes up and the valve pops?? Better plumb that valve outside.........
Have you seen the new crimped copper piping systems?? Guess what it's sealed with??
It ain't pipe doped, it ain't soldered, and it ain't threaded, yet I see it every day and it ain't leaking.
Your family needs to try to save stuff and escape the flames??
#1, saving stuff is what insurance is for, scew it, get the hell out. More people die trying to save stuff than failing to wake up.
#2 Any "working" shop containing anything but minor amounts of flammables should not be attached to the house, period.
Like the fire department is going to keep a list of what's in yout house and where it's located. There's simply now way for them to keep track of everyone's home garage.
And on and on.............
Use what you can afford and what you feel comfortable with installing and using.
Again, I see no reason to use O-ring fittings based upon this logic:
It creates one more possible point of failure.
Sweat soldered/threaded joints WORK. I see no reason to change, other than installation convenience, which the O-ring setup targets.
