Hi Def Wows
ddawg16
S. California
I don't have any...but was doing some searching on amplified splitters....came across this thread...
http://www.highdefforum.com/verizon-fios/97717-do-i-need-amplified-splitter.html
A polite way of implying that 99% of forum members are idiots.
But fear not, Italian "knows it all" and is certainly "smarter" than 99% of this forum.
Quote:
Make sure you dont split anything past this 8 way splitter.. especially not he router.
Of course, if the OP does, he'll find out rather quickly whether it'll work or not.
It may work . . . it may not; the "make sure you dont(sic)" is sort of a lame warning.
Quote:
They should all be home-runs and not a very long distance. If you have any especially long runs, you are ASKING FOR TROUBLE.
Right, keep everything under 1,000'.
Quote:
You could have found a 6way splitter out there to slightly lessen your signal loss.
Let's see, an 8-port splitter will have 12-15dB loss at each port.
A 6-port splitter will have 12-15dB loss at four of the ports and 6-7dB loss at two of the ports.
A "6way splitter" certainly does not lessen the signal loss at all ports; and unless the OP knows he's operating "at the limit" an 8-port splitter makes a lot of sense.
Quote:
Your post is worrying me because you say you have 4 TV's with a 4 way splitter. Your router is likely wired with a 2 way splitter beyond the 4 way. NOT GOOD if your plan is to replace the 4 with an 8. If you get rid of the 2 way and make a new homerun for the router, youll be OK.
I guess some folks can worry and likely and what if themselves beyond all reason.
Quote:
This is the kind of **** that customers do that causes my company headaches.
Fear not, Mighty Tech is here to save the day.
Quote:
Theres always the possibility the 8way can come defective from the factory.. I see defective splitters very often right outve the wrapper.
And . . . . ????
I think some of those members must own SO or CM tools....and used to be here....
Makes our site seem so much more polite
But....it looks like they do have some good info....once you wade through the attitudes...
wyliesdiesels
Modesto, CA
I didnt go to the forum but are they talking about cable TV? I see they're talking about signal loss and splitters but what threw me off is when they were talking about routers....
bmwpower
First page was painful enough, but 5 pages of that banter/attitude?
Cable router?
Kevin C
Portland OR
I used to help out on a car forum... Pretty much a one way thing. A very small forum with a couple of bad attitudes. New members would get replies that their post sucked. I got tired of the negative attitude.
I'm having a lot more fun here.
wyliesdiesels
Modesto, CA
Cable router?
I've been doing low voltge wiring for years and have never seen a cable router for residential or even commercial use before. Cable routers are used in cable headends and COs but not for consumers! Maybe they mean cable MODEMS?
bmwpower
I'm thinking one of those modem\wireless routers in one. But just a guess.
wyliesdiesels
Modesto, CA
Yes, however the device that hooks up to the cable network is a modem. So even though the device theyre referring to may be an all-in-one, the 2 terms are not interchangeable from the cable side of things since the modem is what connects to the Cable Co's headend!
dimarcelli
So if I understand correctly, this guy is ranting about someone using too many splitters?
It's not that hard to check the signal of your cable modem. Some people actually have signals too high and they're required to use splitters to attenuate the signal so it's not so "hot".
madosta
Bahahah! NO they certainly were talking about RF MODULATORS.
wyliesdiesels
Modesto, CA
Incorrect. If the signal of someon's cable service is too high, then its the cable co. responsibility to fix it. I know this both from and professional experience! Yes, a splitter would fix it as well but why bother. Call the cable co instead!
dimarcelli
I apologize if i was wrong. The tech that came to my house installed a splitter for my phone modem stating that my signal needed to be lowered. I can see where it would be a cable company issue.
I guess i just assumed that was how they corrected a high signal.
wyliesdiesels
Modesto, CA
Yes, it is true u can correct a high signal with a splitter but the best approach is to adjust it at the pole/underground tap box or sub headend. This way u dont get a bunch of customers complaining anout choppy signal because of too much gain/high signal!
