chevroletfreak
- Joined
- Aug 2, 2008
- Messages
- 102
Hey all, I've got a 69 Nova that had a vinyl top. I am replacing it and of course there is major pitting along with some pinholes. Unfortunately, no one makes a replacement roof for this body.
Most of the pinholes are in high contour areas around the front and rear edges of the roof panel. I am able to hand form the patches close to the correct profile. The problem I am having is that when I TIG weld the patch in, the sheetmetal shrinks and causes the patch to flatten out and lose its contour.
I have tried both stitch and spot welding with the TIG, but the same thing happens.
The best method I have come up with is over bending the patch and then welding 1 entire side of the patch at a time (instead of alternating to keep cool). Then I will go to the opposite side after it has cooled and do the same thing. This makes it more of an artform trying to play the heat shrinkage game.
Another thought I have considered is creating a flange to mount the patch, but I am concerned that the thicker areas of the roof where the flange is will be evident when the roof naturally flexes in the sun. It is possible that the new vinyl texture will hide that. Don't know, just thoughts.
Any ideas are appreciated. I would prefer the science method over guestimating method.
