roblouvasz
I'm using an older Square D magnetic starter on my 5 hp IR compressor. Originally the compressor didn't have a mag starter, but after burning out the start up windings on the original motor and replacing the motor with one from Grainger, someone recomended a mag starter. The one I'm using is a size 2 type D or T. I did replace the contacts and everything has been working fine. I also purchased a used coil for the starter just for a backup which I've installed to test and it works fine also. So here's my question, The coil part number is S1707 S1 T23A, 60HZ 208-220V, I've found a couple on Ebay that are L1707 S1 T23A, 60HZ 208-220V. Can anyone tell me what the difference between the "S" and the "L" at the beginning of the coil's part number? Will the "L" work also?
