Floor Jack Plunger O-ring
alton
Ocean Springs MS
Sears 1 1/2 ton , model 328.12002. How snug should the plunger o-ring feel? Should it fit the plunger lightly or pretty tight? The plunger OD = 0.784". The o-ring ID = 0.792". Do I need to look for one a couple of thousandths smaller than the plunger OD? Is there a rule of thumb for this measurement? Thank you.
Hiball
Missery
You want the Oring to fit the Pump Piston with a little resistance (Very Little), if its too tight it will distort the Oring and Reduce the Sealing Contact of the Oring. The Most important thing is to make sure you are using a Oring with the Correct Cross-section (thickness). If you use too small of Cross section the Oring wont seal correctly in the Gland, too big and you wont be able to install the pump piston with damaging the Oring.
