I'm not sure on the terminology, gantry maybe means a rolling crane, and I am thinking maybe more of a jib or a portable without a load hoist on an I beam. If I build or buy one it would be multipurpose, but the first job I have in mind is lifting a water heater up on to 19" pedestal with a smitty pan on top that has maybe a 3" high lip. Once I have it I might also want to use it for pulling a motor if my cherry picker isn't doing the job. (no way to get the cherry picker into position for the water heater).
I'm thinking simple, something like a BIG saw horse using metal brackets. For the water heater install one side would be about 4 feet tall and the other about 8 feet tall with a span of about 5 feet. Water heater weighs about 125 lbs. If its not too heavy I might use a steel beam for the cross piece.
Also thought about bolting a pipe etc. on flanges to the opposing walls instead of using legs.
Sound like it should work?
