Grandpa made something like this.
fflintstone
MOFnowhere Mi.
Grandpa made something like this.(update 25AP13)
Grandpa made something like this and I thought it was a great idea. It is very convenient to switch from one power tool to another without having to unplug and replug. The plywood on his finally delaminated a decade ago, and I upgraded his original along with making another.
I lost both in a fire and am now making some others
Grandpa had just put a single duplex outlet on the end of a long extension cord. I upgraded to dual duplex and commercial grade outlets.
This is just a scrap of plywood from our pattern shop at work. Grandpas had shellac on it. I just wiped an oil finish on mine.
Grandpas just had a small hole to hang on a nail, I went with a handgrip for easy carrying.
The final product ready to go.
Spareparts
Lansing Ks.
I did one like this but frequentlysome one would pull it by the cord, either cutting the cover or pulling the cord loose, not really a big deal to repair but I got a strain relief for the box (looks like chinese finger cuffs) and that solved the problem. That is a very handy setup on the plywood.
Norcal
Do not ever use them where OSHA has juristiction, if they are around fines can result.
wssix99
Chicago, IL
Why would I want to do this today when I can buy an extension cord and power strip for less money? Just the proper strain relief for a cord going in to a metal box (not shown above) is $2-3.
F
fflintstone
MOFnowhere Mi.
Because REAL MEN have all the materials required laying around, and appreciate using something they created themselves.
mhm993
Because real men repurpose scrap bits into thoughtfully designed objects that will last decades and feel good in their hands, instead of buying plastic Chinese ****.
John in OH
SE Ohio & Eastern Virginia
Nice item!! There was a setup similar to this that used to be a project choice for the first-year electrical course in 4-H. My brother made one when he was in 4-H back in the '50s. It saw a lot of use until the cord rotted and it eventually fell apart, but still a great learning project for a youth and very useful.
Possible upgrade to improve safety would be to replace one of the outlets with a duplex GFI receptacle and wire the second duplex outlet as a slave to the GFI.
Socophreak
Dont trust the quality of today's consumer grade stuff. Have something close to that in my work van, and I trust it more than any power strip.
F
fflintstone
MOFnowhere Mi.
Yeah, I don’t like consumer grade ****.
To ME there is a HUGE difference between a $.59 home despot duplex outlet and a commercial grade outlet. While home despot sells commercial grade outlets for $6 they can be found online for $3<. I bought several dozen when I started my shop.
I look for old high end stuff at garage sales.
As far as power strips go, I scored a dozen high end $60+ surge/breaker power cubes at a sale once for $1 each. Lost half of them in my first fire.
Blk88GT
Manitoba
I was going to build one of those type outlets for multi use but found this one instead.
I have had some luck, and some bad luck with these. In high draw situations, the contacts in these things cause the outlet to overheat and the plastic melts. Your mileage may vary...
wssix99
Chicago, IL
Yes, but WISE MEN use a proper strain relief:
Grampa probably would have used an underwirghters knot:
images
This is a key thing worth mentioning for folks who might do this project and not have experienced with the proper relief or knot.
I recently made a similar rig as you did for a specialized project and the strain relief cost more than all the other components - but its a lot better than having an energized cord pull out of the box.
wrench409
Over here....
Thanks.
I just rewired my garage completely and only use extension cords for short times and hard to reach places in the yard - leaf blowing, bush trimming, etc.
I will keep an eye on this cord when I use it.
Great idea to inspect cords regularly anyway.
LEVE
On the Willapa
I would like being able to coil up the cord and then uncoil without it turning into a rats nest.
I've used these boards with boxes affixed. I did find that you'd best have a good grade of extension cord wire. I had wire break on the first few wraps around the board from continued use/flex always at the same point. But it worked... however, there are a couple of other ways to do this.
The first is called an "Daisy Chain".
Here's the method I use:
Looping Method
I first tried the daisy chain only a few times and it seemed a little unwieldy when I tried it. But after seeing the video, I may revisit it. I can see some benefits over the looping methods.
That about wraps up this looping stuff! :beer:
F
fflintstone
MOFnowhere Mi.
So I am working on a second one with my son. I wish dad and gramps could see it.
Note the child size latex gloves I recently scored.
cousin eddie
western pa
dont know if id consider myself a "safety nazi",but i must commend you for making your boy wear eye protection. a good habit started young will stay with him. after all, GOD only gave you two eyes.
Howard Sterndrive
Using a metal box on an extension cord is tricky. I *think* the code says to not bond the ground to the box. And then the receptacles should probably be orange as in isolated.
thdewey
Gastonia, NC
Thanks for mentioning the strain relief. I'm going to redo my extention cord box this way. I used a 4 socket box (GFI). I thought that the regular clamp was enough.
And fflinstone, as for your son working on your new board to replace Grandpa's....my eyes aren't misting up. I...I was just cutting some onions up... Promise.
Vegaman_Dan
Pacific, WA
The advantage to making your tools like this is that you can freely modify, change, improve or repair them if something goes wrong or you just decide it would be cool to add _____.
I've done this same setup in the past, but not with a board backing. I like that idea a lot. The one thing I did do was add a light switch as one of the slots in a 3 gang box so I could turn off the power locally without going all the way back to the plug in the wall. Today if I were to make one of these- and I think I want to, I'd do similar. Four outlets, switch, maybe with a light on it to show power is hot.
I love the slot cut into the board for easy handling. That alone is a great tip.
