IDK...but check MaH as well.
My blue Makita drill takes 3.0 MaH batteries, and will not fit the white Makita 1.5 MaH batteries. If you grind the tab off to make it fit, the 1.5 can not give enough supply to the demand of the drill. And you'll burn it up. That's why MaH is important...
Not sure bout this one. Mah is a capacity, not a use rate, so the issue seen is likely not related to that. A lot of drills have 1.5 or 3 interchangeable packs, just the 3 is bigger and more expensive.
