blindbug
Re: what did you do in your garage today?
I took all the interior pieces out, hung them over my saw horses and hosed, hosed, hosed... I probably hosed them for a solid hour in total!
I then let them air dry in the sun for a bit, then sprayed them down again! I can run my hand across the fabric and feel the detergent lingering on the edge of one piece, but other than that, everything looks clean (ha).
I'll have to make a run down to the hardware store for some real grease on the jack now. Thanks man.
How did you clean out the detergent? When I cleaned puke out of my carpet yesterday I spreayed water on it and used a wet vac to pull the water and puke up. The reason I ask is that detewrgent would need a LOT of rinsing to get it all out of the carpet. Leave it there and your carpet can be destroyed.
As for the jack, thoroughly clean it off, grease the joints and screw and you should be fine.
Jim![]()
