Ign
I need to build a quantity of crude lynch pin latches for door closures. This is nearly identical to trailers with fold up ramps: a bar with a hole(s) in it passes over a stud with a hole drilled in it. Lynch pin inserts in hole in stud.
I can't imagine trailer manufacturers are custom making these studs, but I can't find a source. Similar attachments are found on tractor 3pt hitches too. I CAN make these studs myself by drilling round stock, but the quantity needed makes this impractical.
I must not be searching the right places or using the right search terms. I've searched the web and a couple trailer supply websites, but only found lynch pins themselves. Suggestions??
I've considered hitch pins, ie pins with multiple holes drilled in them for cotter pins, but the holes would be too small and/or the cost too high. I really just need mild steel round stock with a single hole cross drilled. I can adjust thickness of my bar to compensate for hole placement, to some degree.
