rsieracki
I have an older gasoline powered 5000w or 5500w (i cant remember and its buried in my shed) generator that id like to make a quick connect setup for.
what im thinking is its has i believe 2- 110 outlets and a 2- 220v outlets on the genset. im going to get a schematic and see about changing that to a single 220 volt output (at the 5500 watts or whatever the actual output is) with a twistlock connector that i can connect to a twistlock on my deck that will run apx 40 feet into my utility room (thru crawlspace) I AM NOT LOOKING TO BACKFEED SO LETS KEEP THAT OUT OF THE THREAD
What im looking to do is have this line run into a subpanel and split into 3 or 4 outlets to run a short extention cords to the freezer, sump pump etc. i know i cant run home off a genset of this size so im not planning to try. What I'm simply trying to do is elimiate leaving a door open and several different houndred foot cords run thru the house when all I need is the power ran into my basement (much shorter run) and I can run cords from there and keep the home closed and secure.
what im asking is:
1. What guage wire for a 40 foot (apx) run for say 5500w genset
2. Seeing as I'm navaging it thru the crawlspace (completly enclosed it has a concrete floor as its the crawl under an addition over an old patio) can I use that flexible metal (spiral metal and looks like BX only you pull your own wires) or is a NM cable acceptable? perhaps the grey waterproof tubing (name escapes me right now) RUNNING EMT IS NOT AN OPTION, I dont have the space and it would be a royal PITA in the space I'm working in.
3. has anyone done something similar? i cant find a thread on doing what im thinking.
Thanks,
Ron
what im asking is:
Thanks,
Ron
