Hello,
I live in Mesa Arizona, an adjacent city to Phoenix. As you may of heard it gets a little warm here in the summer. Like over 110 degrees. I'm going to replace my 1977 single piece steel garage door. Not only is it starting to fail and I can't get parts but my house faces west. During the summer the sun beats on the steel garage door and turns the attached garage into a dry sauna. It's hotter in the garage than it is outside even though outside may be over 115 degrees. The heat bleeds into the house in spite of insulation in the garage walls and pushes up my air conditioning bill.
Every article I've found talks about insulated garage doors and cold. Cold is not my problem.
Any suggestions as to the best brand of insulated garage door for heat?
Since I have to replace the door anyway I don't see much point in getting another steel one and trying to insulate it.
I was thinking of a polyurethane sandwich style door. My reasoning that even if the door leaks air around the edges it will still be better than what I have now. I am aware that the R values quoted by manufacturers are not consistent since some use the center of the panel and very few, if any, test the whole door.
I've already put in Energy star windows and doors and had extra insulation blown into the attic. I have dropped my utility bills by over 35%. I've also installed ceiling fans which help a lot.
So in my particular case is an insulated door worth the extra cost? Does anyone have any experience with a particular brand?
Suggestions anyone?
Suggestions anyone?
