Hanging OSB on Ceiling in shop
jmillspaugh
Going with 1/2 OSB on ceiling and walls. Question is do I need to run stringers on trusses or can I attach OSB directly to trusses. Its a 24X24 with 12' walls. Trusses are on 2' centers.
Highbeam
Mt Rainier foothills, WA
Since you sheet the roof of a house with trusses on 24" centers and 7/16" osb I would do it. You walk around on that roof with that spacing and even pile snow on it.
With the roof deck you also use these metal clips at the sheet edges. Do you guys use the clips?
ringneck
Eastern Nebraska
Were the trusses built to support a ceiling load? You can probably get away with attaching them directly, but if the trusses werent built to support a ceiling load you are weakening the structure. Adding stingers will only make it worse (more weight on the bottom chord).
mark52621
I attached osb directly to the joists, and I should have used stringers. The boards of the joists are on edge and very narrow. It's not bad until you start the second row, and each row after that gets worse.
If the walls or joists aren't square, or you don't get the osb put on perfectly then you have to trim each sheet so you have room o screw on the next. It was a major pain to do.
If you're careful when putting up stringers putting up the osb will be easy.
Coursey
Kentucky
I had it in my last shop, and i am using it again in this one.
Hang it direct to bottom of truss, and run it perpendicular.
dbonne
Southern Idaho
I assumed when I hung 7/16 OSB that the sheets were 48 x 96. I learned the hard way that they are 1/8 inch shorter in both directions (for installing "I" clips in roofing applications). When I had 8 sheets installed, I was off of the framing member, scratching my head. 1/8 spacing is needed to keep on center!! I used 1/2 crown construction staples, those sheets won't come off without ruining them, something else I learned the hard way!
View media item 30245
Nowater
Southwest Florida
One way to "fix" a spacing problem is to sister a 2 by 4 even with the bottom of the trusses and then use the new 2 x4 as a point of attachment. No one will know it is there except for you! DAMHIK.
Blk88GT
Manitoba
Nowater - great tip. Also a tip someone gave me AFTER I was finished. Wish I had thought of it during the process ;)
You get pretty good with a belt sander after sheeting the inside of a large building... LOL
Spudland_Dave
Maine
Strapping the underside of the trusses 16" OC seems to be a regional thing. Where I'm from its the only way to fly...NOT doing so is seen as "Hack Job"...last week at this time thats precisely what I was doing:
Slednut
Washington state
I think it's a trademark stamp or something. As much as it happens, there can't be a machine running with that many loose bolts or ones that have fallen out.
:beer:
They're all over the place, screws, bolts and nuts, a lot of them you can't see during the day but at night when the lights are on they are easy to see. The bolt in the picture looks like an old one.
Slednut
Washington state
I don't want to steal the tread but here is a pic with what I'm talking about circled.
pattenp
Virginia - USA
I see now what you're talking about. At first what I saw looked like a bubble. But now it looks like a prehistoric fish fossil. So just how old is that OSB?
