Best drill bit for drilling through a wrench?
rlitman
Long Island
You guys rock!! :beer: I got through the wrench without any problems using the Irwin Multi-Material drill bit (4935109) listed in the picture. My drill press was set at 1100 rpm but I should have changed it to 600 which was the next option on my machine.
Multi material bits rock! Just last week, I had to drill through a steel door frame set in concrete. Nothing else would have done the job.
I haven't seen that Irwin one yet, but it's good to know I can buy them in single sizes too.
Derrickwade
Illinois
I'm glad I stumbled across this thread. I was trying the same thing, except with a handheld drill. I wasn't getting very far and finally gave up. I might just give it another go with that special bit. :)
E
Exceller8
Banning, CA
Just make sure you use some oil to cool the bit and you'll be good to go. :thumbup:
5mall5nail5
Bucks County, PA
Can you imagine the reaction if an IT/phone guy asked to use some of the power tools at work? :evil:
Happens all the time. I am a system admin/DBA/network admin/etc. and I actually weld things up for my workplace (DOD contractor). I go into the tool room and use the lathe, mill, surface grinder, etc. Don't be fooled!
We needed to make a HMMV mount for the whip antenna because we ordered X and needed Y. I said measure it out and I'll have it welded tonight and in work tomorrow.
Quijote
Greater Boston
I learned all I needed to learn when trying to drill out a busted locking bolt on my Volvo (lost its shape due to a crack and key would not work anymore). I tested it at work and it was 60Rc. HSS, even TiNi-coated HSS did nothing. Cobalt worked but dulled quickly so it was slow progress. I then got masonry bits with carbide tips and drilled slowly. I mean under 100rpm slow. It cut like butter. Brittle as hell, and I had to do this freehand, so I went through two bits. It worked though. I was getting close to giving up and cutting the $300 alloy wheel off the car.
I know I am just echoing what guys have already said, jut telling you m y experience.
I'm not implying they can't do it, but the reaction from a shop manager will usually be :wtf: or there would be a policy about "qualified" personnel only... :dunno:
ATC
VA
Well, I've been following this thread, and finally decided to make a wrench handle for my HF cart. I put the wrench in the vise, chucked up a 9/64" drill bit, and went to town on it. My standard Dewalt coated bit ate right through it in seconds. I even drilled through the thick part where the handle meets the head...
E
Exceller8
Banning, CA
Looks great! :thumbup:
