HF 1-ton vs. 2-ton shop cranes
Quijote
Greater Boston
There are coupons readily available for the 1-ton crane for $99. I was planning on getting one , but I seem to read insinuations that the 2-ton crane is much better.
Can someone with experience with either, or ideally both, comment on the differences beyond load rating? Is one significantly larger/better built/easier to use/etc.?
The 2-ton also seems to not have particularly great coupons if any. Even a great 25% coupon puts it at near $200. Is it worth double the 1-ton? I will seldom use either, never mind need the 2-ton rating, but I would get it if it is a better product.
Thanks.
EDixon
Aiken, SC
I recently sold my 1-ton and got the 2-ton. The extra height and reach is the biggest advantage. I could barely get engines in and out of the bed of my Avalanche with the 1ton, but the 2 ton did it yesterday with probably another 1.5feet of lift available.
RCStocker
Indiana, California, Australia
It is not that bigger is better. The 2 ton has a longer boom arm and will raise up higher. Many times you need the extra height when removing an engine form a truck or larger car. I use my picker to move heavy bench top lathes and milling machines. Buy the larger one. I have a HF and I have used it to pull small tree stumps and it has worked very well for the past 10 years.
diesel research
gulf coast, TEXAS
Thanks.
that's what you think
the typical crane has 4 different boom reach holes. Each hole loses between 500-1000lbs of capacity. By the time you've reached the fourth hole, you are down to a mere 500lbs. murphy's law dictates you will be operating mostly in the extended reach portion.
