Bigger Air Compressor advice needed!
Keyblazer
Irvine, CA
After years of using my trusty but weak Sandbourn upright 30G/125psi/3hp unit I am ready for an upgrade. It has been a huge restriction on what and how long I use the air on.
The basic wiring is in, with a 60a box in the garage bringing 220/110 within reach.
I want to run a good size media cabinet, with whatever I want, inc Soda.
Air tools, like a DA and grinders.
Only me in the garage, working on home projects.
Looking at this one for $489. 155psi and 10cfm/90psi.
http://www.homedepot.com/p/Husky-60-Gal-Stationary-Electric-Air-Compressor-C601H/203187350
Or the HF big boy at $799.
Two stage, 165psi, and 15.8cfm/90psi.
http://www.harborfreight.com/5-hp-60-gallon-165-psi-two-stage-air-compressor-93274.html
Opinions please?
devoncoolman
quakertown pa
honestly I wouldn't buy either one. I would buy a used one. the older us made compressors are way better than those. I bought my ingnersoll rand a long time ago. bought it for $400 and threw a new motor on it for $200. works great and an 80 gal tank.
bseant
central valley,cali
i second that. I bought a used 1957 ingersoll and rebuilt it for about a 150 bucks and it should last me another 60 years. Nothing beats old usa steel.:beer:
CNGsaves
KS and OK
x3 to skip both the Husky and HF . . . since you already have midrange.
Keep looking for CL score of lifetime quality compressor (60 gallon minimum).
zkling
x4
Look for an older quincy, champion, kellog, american, commercial IR. Something that runs slow and pumps lots of air. You will be money ahead. If you really want to get into soda blasting, you will want something closer to 20CFM @ 90psi
K
Keyblazer
Irvine, CA
Thanks for tthe input so far Peeps...
Since I live on a residential street and the garage is attached to the house... soda blasting a WHOLE car or outside the cabinet is probably a No-No.
:shocking:
I spent a while looking locally for an older unit but nothing looked better or cheaper than the new ones so far... still looking!
zkling
:shocking:
Even a good size cabinet will take quite a bit of air to run properly.
If you are stuck buying new. What is your budget if you don't mind me asking?
Either go with a true 2 stage or a regular single stage. None of that want to be in between 155psi nonsense.
Where are you located, roughly?
pipsters
USA
All the cheaper mid-range units spin pretty fast. In the 1200-1500 RPM range. IMO that is about 2x as fast as a compressor of that size should be spinning. Even the lower end Quincy spins at 1300 RPM.
High RPM = noise, heat, & wear.
New, stepping up to a lower RPM compressor putting out good #'s you're looking at around $2000 and up.
Me, I'd get the HF (even better deal when they were $699 and took the 20% off) and run synthetic oil of some sort in it.
bseant
central valley,cali
oh man with 800bucks you could rebuild yourself a very nice compressor. Would be more air than you could use if you have the time to do it. would be very worth it in the end. Being in socal your options are pretty good in finding stuff.
CNGsaves
KS and OK
Using Google, you can filter through CL and find what you want. Example:
Quincy compressor site:craigslist.org
Here's a Quincy 325 a little roadtrip away . . . Yuma, AZ . . but it has a 3 phase motor you'll need to change out.
Negotiate down price and this would be lifetime keeper.
http://tucson.craigslist.org/for/3665533601.html
Found a second Quincy . . . Model 310 Duplex (yes . . . DUAL compressors) but again it's 3 phase. That would be a Beast for sure !! See second picture.
http://charleston.craigslist.org/bfs/3756344719.html
Found a third Quincy . . . 80 gallon / 5 HP / 240 volt that includes a dryer!!! It's in Denver,CO and only 4 years old for $1,000 OBO . . . this would be the setup for you, or someone on GJ as this looks like great deal.
http://denver.craigslist.org/tls/3787182496.html
K
Keyblazer
Irvine, CA
Thanks for the finds...
Couple of things...
1/ MUST be a vertical tank unit, as I have no outside space and a 2 car garage.
2/ Max budget is $800 ish... not $800 plus fixing and gas.
I am in SoCal, so driving more than a couple of hundred miles round trip in my Pickup at 8mpg... is not on.
ILDurable
Homer Glen
Go with an Ingersoll Rand compressor. Either a 60 or 80 gallon. Both are reliable, perfect for what you want to do and with IR, the service is always there. A little more expensive but worth it in the long run.
bseant
central valley,cali
damn u would think that socal would be a hot bed for stuff like this due to just shear population. There's nothing in your local craigslist? pretty sure op isn't driving to colorado to p/u compressor.
bseant
central valley,cali
searched los angeles craigslist for "compressor" and got 4 pages of results. Don't know what part of socal you in though. You gotta do the leg work and rewards will come. Don't fall into the pit of new china.LOL
bseant
central valley,cali
What about a Speedaire?
speedaire is decent depending upon price.
Buy the hf and get it over with. You're not buying a burial plot. Its a damn compressor, it'll do what you want for many many y ears, then sell or scrap.
GET A COMPRESSOR NOW, THEN LOOK FOR LOVE WHILE YOU'RE BANGING THIS ONE.
that's sounds like a measure once and cut ten times philosophy.:lol:
mayday0017
Houston Texas
Speedaire can be great depending on the price.... Look at the pump if it looks like an R15 pump, the unit is really a Champion with a Speedaire sticker on it.
zkling
What part of "Socal" are you in?
Maybe check out that Atlas for $150, although the sellers pics leave alot to be desired. :lol_hitti
K
Keyblazer
Irvine, CA
Waiting for info on the Speedaire....
Also.looking at a Husky..
Lookin everywhere!
I will travel in socal if its worth it!
K
Keyblazer
Irvine, CA
To clarify for those who did not read the whole thread.....
I have a Sanborn "Peak 5hp" 30 gallon upright.
But it struggles and is holding me back, so I asked for input and opinion on the HF and HD units.
I am happy to pay up to $800, for something that matches or exceeds their performance, and has a longer life with maintenance and refurbs.
Those that have added value and sensible guidence, I applaud...
If I find a used one that works for me, thats great...
I asked for educated opinions...
Zeke
Speedaire is Grainger's brand and they are pricey as with all things Grainger. Good units.
How loud is the Sanborne? The Husky will not make you friends with your neighbors. Like the difference between a chainsaw wide open and a 4 cycle mower at part throttle.
rodm1
I would go with the HF model, If you just look at the specs you might be better off getting 2 of the HD models and hook them up in series.
Blasting and DA and grinders takes terrible amounts of air you will need every bit of air either of those can put out and probable more.
To do it right you won't a industrial 5hp+ that is oil lubed. With a 80gl tank or better. But you will pay dearly for it.
doan
Frisco, TX
I think the issue here is that $800 will not get you a new compressor that will make you happy. I have a 60 Gallon that does about 12 CFM at 90PSI. It can just barely keep up with a die grinder. To move into the 20+ CFM range is going to cost a lot more than $800.
For $800 the HF model is probably the most CFM you can buy "new". If you want to grind, sand, or sandblast all day, it is probably not enough.
CNGsaves
KS and OK
Not necessary to have "brand new" compressor to get CFM you want for reasonable amount . . . . IF . . . you're willing to look everywhere and be willing to act quick for a bargain.
See thread where new GJ member with 9 posts picked up Champion 5 HP / 80 gallon compressor 2-stage for $250 . . . . yep, here it is:
http://www.garagejournal.com/forum/showthread.php?t=200260
Charles (in GA)
50 mi south of Atlanta
OP only has a 60 amp breaker panel in his garage. Probably cannot run two compressors and the lights at the same time. He needs one decent compressor.
True 5 hp (two stage) will give you about 18/19 CFM and about 20/22 amp draw, and true 7.5 hp (two stage) will give you about 24 cfm and about 33 amp draw.
Charles
All
That Husky so called "7 HP" is NOT 7 running HP. It is 7 "peak" HP. In otherwords, it is BS advertising gimmicky stuff.
To put it in relative perspective, the true 7.5 running HP motor I have could be advertised as having 21.4 "peak" HP, but fortunately, by the time one steps up to industrial sized compressors, a lot of the marketing malarkey is dispensed with.
Not saying that the Husky (that particular one is made by Campbell Hausfeld) is a bad compressor, but it is not the "bad AZZ" compressor that it purports to be. The true running horsepower of that motor is about 2-3 HP. You'll get about 15 CFM out that unit, not the 25 CFM out of a true 7.5 HP unit.
All
Another thing... I noticed in the pics of the other ads you posted that these compressors were in a commercial environment where there was a possibility of employees present (evidenced by forklift, many pallets, etc). If this is the case, then it is highly likely that at some point or another, an OSHA inspector came in and inspected the tank.
Given the age of the labels on the tanks in the pictures that you showed, the probability that the tanks were at some point inspected by OSHA is even higher. This applies to California and metropolitan areas of New York, the two most progressive (some would say aggressive) coastal states with highest population densities where regulations (some would say invasions) are on the cutting edge.
So, if CAL-OSHA inspected those tanks, they would have stamped (with a punch) a serial number on the head of the tank. The numbers would be at least 1 inch in font size. When you look at the tank, look for that serial number, and write it down. Then, go out to your truck and "think about it" for a while, and while you are thinking, call the OSHA office in So Cal that is responsible for keeping track of state inspections for pressure vessels, and have the record pulled for the serial number you obtained.
They can tell you on the spot if the tank was condemned for use in commercial service with employees present. They will have made that determination utilizing an ultrasonic thickness tester, comparing their readings with the minimum thickness specifications found on the welded on National Board Registration tag that is part of every code welded ASME pressure vessel, which all the Husky's in your links have.
This way, you don't get burned by a business craigslisting away a condemned tank they can't use in their shop anymore. Also, look for any circled X punched into the tank. That is a sure sign of state condemnation.
2jz4me
se indiana
I would without question buy a used t30 ingersoll rand. Dont buy a junk compressor now only to replace it later. Buy one now that could last you for as long as you want it to.
