Its about right.
I highly doubt a 5hp compressor is making 19 cfm. Could be wrong though.
I think it is quite quiet. I had an OLD Westinghouse air brake compressor that I could hear outside with the doors shut! This one is very quiet compared to that. Also rechecked the 0 to full time and it is a consistent 6 1/2 minutes. Tom...This makes me even more ready to get my new unit hooked up! How loud/quiet is it compaired to other 5hp units you have been around?
I calculated 18.1 CFM, 80gal tank, 6.5 min to fill from 0 to 160psi.
What are the pump CFM specs?
Check belt tension and change oil just to make sure it is operating up to snuff
How did you calculate that? What kind of time is appropriate for a 60gallon to 175psi at the same 18cfm?
