Tool for twist-in brake calipers?
Frosthy
FL
I saw the "cube" on ToolTopia yesterday but now I can't find it... Anyone have a link? I'm also confused as to how that tool is to be used?
aleccolin
It's just a universal brake caliper tool, you can get them at any auto parts store. The pins are sized and spaced to fit the slots in different caliper pistons and the cube accepts a 3/8" drive ratchet or extension so you can press in while you turn it, which is the only way many rear calipers with integral parking brake will retract for installing new pads.
ken w.
Western New York
The cube works well on very few calipers in my opinion. When the cube is easy to use , you most likely could have used a pair of needle nose to rotate the piston. I prefer the kit with the adapters. Up here in the Northeast I prefer to replace calipers more often because the piston tends to rust up and stick from the salt and slush we drive in.
zkling
Cube *****, I would get the kit with the different adapters
X 10000 :lol_hitti
Same as above just a bit more detail. If the cube will work, so will a pair of needle nose pliers. You need a pushing and twisting force to compress the piston the threaded adapters work well for this.
MeentSS02
Dayton, OH
I bought a cube from HF to use on my Viper's parking brake caliper pistons (they require the push and twist method to retract), but none of the patterns lined up with the holes in the pistons. I ended up using a set of 90° bent needle nose pliers to do the job instead.
I'm really not sure what calipers the cube type tools work on, but it sure wasn't mine. It would have been great if it had fit, but I guess you can only cover so many bases with that type of tool.
dclassical
Following the advice of someone here I got the Lisle tool kit:
Lisle 25000 Rear Disc Brake Caliper Tool
It works very well and their warranty department is just great. I had a problem at first with the main part being a little too big to fit completely inside the adapters. One email is all it took for me to get a replacement part.
volvo92906
Northwest Ohio
I used the cube every day when I worked at Honda. A 7.00 tool compared to some 50.00+ tool that does the same thing but with discs instead? I admit its nicer.. But I never had a problem with the cube. I guess my main reason is since I mainly work on heavy stuff, I didnt want to spend the money for something to work on cars for a short time.
mrborohachi
Berdoo Route 66
great post as to the merits of the Cube :beer:, cheap, takes up less space than a 3/8th dr deep socket. It's a great on the road tool for when you go help a friend do brakes
Jeeper
Round Rock, TX
I used the Lisle cube on my Pontiac Grand Prix rear brakes and it worked fine. I can understand if you did a lot of them, you might want something different but it worked fine for me.
tjmonsen5
Crystal Lake IL
The cube *****. It works on nice newer cars with pristine calipers. On an old rusty caliper, forget about it.
I use the LIL25000, i had to do a Nissan maxima brake job last night, and had to use my impact gun to turn the caliper in. The rubber seal was torn on the piston, and it was all rusty. I reccomended the customer buy a new caliper.
rob0781
Canada
I used the cube on my 05 acura rear calipers, 180,000km and the original calipers driven thru canadian winters with lots of salt and the cube works great on them.
stephen4785
Benbrook, TX
All I do is leave the top caliper bolt in then swing the caliper up and prop it up with a wrench. Then stick a large flat blade screw driver through the top of the caliper and use it to press the piston while I turn the piston back in with some channel locks. As long as you dont squeeze the pistons too hard while turning it it works great.
shampoop
SW Washington
I have the cube and don't like it much. I like this much better.
http://www.tooltopia.com/sunex-tool...utm_term=SUN3930&utm_campaign=pricegrabber_r1
cburnscrx
Indianapolis
I tend to do a lot of work on Honda's (CRX, Prelude, Acura CL), and I've used the cube too. Works just fine and was cheap! I am sure one of those kits works very nicely, but for the cost, grab a cube from any autoparts store. If you don't like it and you want a kit, you're just out a few bucks...
jeffk14
GA
If I were doing rear disc brake jobs every day, then I might opt for a fancy kit.
For the rare occasion that I need it, the cube is just fine for me. I've even got one or two that I've "modified" by grinding the little knobs to fit vehicles that the cube would not have otherwise fit. A couple of cubes laying in the drawer takes up a lot less room and is a lot less to keep up with than a kit too.
dirtmister16
wisconsin
i have a otc kit on here, but i also think the cube is easier, faster and nicer. at least you can push and only need one hand. no setup time just slap it on the extenstion.
it doesn't work everywhere but it does work in places when the kit doesn't have anything that works.
