What's behind this horizontal beam in Garage
PoorOwner
CA
Does anyone know what is behind this beam in the garage.
I want to put some screws into studs for storage or TV mount, but wanted to be sure there isn't pipes behind it.
ccoffing
Looks exactly like the beam in my extended garage in my old house, supporting the trusses so the garage could have an addition. Probably a 4x12" wooden beam covered by drywall. I'd feel fine running some lag bolts into it, no worries.
ADSR
Who knows for sure. But it looks like it's just load bearing for upstairs.
pendragon1998
NE Georgia
Maybe borrow one of those infrared cameras? Listen with a stethescope for water? I'd be concerned about drilling into a live wire.
Kracin
Omaha, NE
drill a small hole, 1/2 or so, dont go deep. and then use a snake inspection camera from HF (80 bucks). just another useful tool at work. then you can easily patch a small hole like that.
kert
Franklin, MI
It looks like the beam is about 4" wide from the picture. There would be no way to reasonable put plumbing/electrical plus the support structure and 2 layers of sheetrock in that space. I'd be pretty sure that it is a solid beam and if you tap on it you'll find it sounds solid and not hollow. You should be safe to put screws/lags in the middle of it.
Tim The Tool Man
Lehigh Valley, PA
90% sure it is just a beam. If it is an LVL (laminated wood) then you can screw right to it, If it is a steel I-beam then you will need to think about how to properly secure a TV bracket because the sheet rock alone won't be strong enough...
NUTTSGT
Northern Central Ohio
My parents house has a beam just like that in the garage, laminated (flat) 2x6s.
If you want to make sure, you could always cut a section of the drywall off and repair it. Since it's on the beam and generally people don't look up, it won't have to look "perfect" if you've never done any drywall finishing.
P
PoorOwner
CA
Here is a view from outside, it seems to be where the upstairs room's exterior wall starts. If you look at the side window of my original pic you can get a reference of where this is.
So I think it is just a support beam.
JakeKohl
Greenville, SC
There would be no reason to run anything in that beam to an exterior wall. However, check that you don't have HVAC registers directly over that beam upstairs or a hose bib on the exterior in line with it...should be good to go.
CNGsaves
KS and OK
Selective exploratory demolition. It's just drywall.
^ ^ ^ This . . . . small drill bit will pull first 5/8" as white sheetrock dust, then after that should be sawdust if it's wood.
Drill your first hole and hang something (besides a TV) on it to test it's holding capacity. Of course, don't park car underneath it if your "test weight" might fall down !! :D
ddawg16
S. California
I have a 7x16 PSL beam running across my garage....it supports the floor joists for the second floor 'storage'.
P
PoorOwner
CA
maybe something like this
I think it is nicer to store this way than ceiling hooks.
+Wall speaker mounts
tcianci
Walpole, Ma
It's a beam alright. If you need to hang something, just keep drilling till you get through any wires or HVAC stuff. You'll hit plenty of wood to anchor to eventually.
JakeKohl
Greenville, SC
I might add to that, if it hisses, it's probably a refrigeration lineset or gas line, if stuff gets wet it's probably plumbing, and if it sparks it's probably electrical. :lol:
