Cemoto
Guys I could use some advice here please.
The foundation is in and the floor and pads are poured.
I'm at the point of choosing materials for siding.
Although the garage sits well back on my property the facade will be seen from the road. I'd like the facade to match the house which has stained red cedar. That stuff is hugely expensive, but it won't be bad to do the front due to the large doors.
I think I'd like to do vertical steel on the other three exterior walls as they face the woods and the durability of steel appeals to me.
This build will have a conventional asphalt shingle roof and frame with soffit and ridge venting as well as an electric roof fan.
There will be 10' walls w/ a full-length ledger fastened above on the gable ends for a future lean-to.
So this leaves me w/ 10' walls. I looked into T-111 and unless I wanted to buy a truckload I could not find 4'x10' sheets.
The steel seems to fit my purpose.
The plywood/OSB on a stick build adds structural integrity. I'm not sure steel would do the same by itself, so strapping or sheathing underneath seems to be in order.
Long winded post I know but I wanted to provide all the details.
My questions are as follows:
If I was to attach vertical steel directly to the studs would it provide enough structural integrity?
Would I have a moisture problem if the steel is attached directly to plywood? It is in a somewhat damp area but not rainforest.
If the steel is applied directly to the studs can I use spray foam insulation or will the steel rust underneath the foam?
Any thoughts or suggestion will be greatly appreciated!
Thank you!
Thank you!
