bfarroo
I've been talking with a few different contractors the past two weeks to get quotes on buildings and site prep. One mentioned that his concrete guy said the vapor barrier should go over the foam to keep the concrete from seeping down between the cracks between the sheets and leaving lines in the finish. I've never heard anyone do it that way and I told him that typically the vapor barrier goes down then the foam on top. Have any of you heard of this happening? maybe the mix was to thin? I know I've seen some people tape the foam together which I may consider if it could be an issue. Also is there any value to putting the foil type insulation in the areas where the lift will go? I'm thinking not but figured I'd ask. Have any of you had issues with the foam wanting to blow away after it gets put down before the tubing gets installed and the rebar gets set?
Thanks for the help guys,
