Flexia
In the process of planning my garage out back. Not to sure about what utilities I will run out there. What are are pros, cons for gas or electric instant water heater for a 1200sq slab.
If gas is available, use it. To heat this with electricity you will need an exta large service.
Out of curiosity, what do you pay for a KW of electricity? In most cases, gas calculates to be cheaper.
In most parts of the US natural gas is cheaper for heating than electricity.
Agreed, but for some without NG, electric heat may make sense.
My only point is a water heater uses electric resistance heating which is less than 1/3 as effective as a heat pump (or more) as long as it can keep up and doesn't revert to the "emergency" supplemental heat strips.
So, given the goal of any good heating system is to use the least energy possible...I (personally) would not consider using electric in floor hydronic heat....except perhaps using a heat pump water heater (which I don't know anything about except they are really expensive).
Around here, they used to use a lot electric resistance furnaces in houses or even electric resistance cable in the ceilings or baseboard electric resistance heaters throughout the house. All of those are gone now. People just couldn't afford to heat that way. There are better-much more efficient and/or cheaper options. NG would be 1. Heat Pump would be 2.
Phil
You're right, you don't know much about heat pump water heaters. There is no common product available that uses a heat pump to heat water for floors. There are a few domestic heat pump water heaters that are very low output and depend on a backup resistance element for high/normal use times. The output is lower than a typical 4500 watt element which would be too small for most floor systems.
It would be great if the same technology that the minisplit air heating systems use could be applied to water heating. Shouldn't be a big leap. One rare european company does it, daikin, but they are rare and extremely expensive.
Until then electric water heating means resistance heating and when NG is not available, electric resistance heating can be the cheapest.
So they don't exist...except for the one that does exist? And (like I said) it's expensive. Sorry I was so misinformed.
Seriously though... when you say "electric resistance can be the cheapest". Given the fact that a modern heat pump will average about a COP of 3 to 5, and WORST CASE it will revert to 1.0 on emergency heat...how does it ever use as much electricity as resistance heating which always runs at a COP of 1.0?
Are you saying because the equipment is less expensive? If you're getting to your conclusion using a payback calculation (i.e. Heat Pumps are less expensive to operate but they cost more)....then please make that clear.
I'm trying to make a basic point, which I can tell you are probably already fully aware of...Heat Pumps use less power (by a lot) than standard electric resistance heating. It's a basic concept that people should appreciate before making their equipment choice.
Phil
Okay. Yes, there is one oddball manufacturer in a foreign country that makes such a device called a heat pump water heater suitable for floor heat. That is why I said that there are no common sources of heat pumps to heat your floor. If you choose to import this device then you will pay a lot of money and there will be little or no support when it breaks. This eliminates that one oddball manufacturer from the candidate pool.
Your basic point is flawed as there is no available device that does what say to heat water. All currently available heat pumps heat air, not water, so comparing the air heating efficiency of this imaginary device does not contribute.
I am currently running wiring for my in floor electric resistance water heater. If a heat pump water heater, using modern inverter technology and typical floor heat btu output was available then I would love for you to show me.
We want the same thing but I have looked and came up empty handed.
Right. Agree.
So, the only thing I may not have made clear yet...and then I'll let you get the last word...
Your a goof aren't you?
There, last word![]()
