big Compressor mounts/feet
tonycastec
Los Angeles
I need to add some vibration(& noise) absorbing feet to my 7.5hp 80 gall Quincy.
The usual advice is hockey pucks, rubber mats. I just wondered if anyone had tried using hydraulic motor mounts intended for a pick up truck. They are not cheap but I presume they should work much better than the usual items?
As an alternative, what about old-fashioned rubber motor mounts for a truck engine?
Grateful for any specific experiences shared.
zkling
You would have to look at the durometer or stiffness of the mounts and compare it to something more common.
I use hocky pucks and have never had a problem. Just from the seat of my pants I am thinking that the hydraulic mounts and engine mounts may be a bit soft (low in stiffness), but not sure.
Be careful if the mounts are too soft as they main gain an amplitude (shaking motion) and could possibly cause the compressor (extremely top heavy) to tip over. If you did use something soft you may want to anchor the compressor to the floor through the mounts.
T
tonycastec
Los Angeles
Mine is a huge 2 stage compressor mounted on concrete outside.I am currently designing a weather -proof 'shed' on wheels for it.Wood mounts will rot over time and the resulting uneven support would be a problem.Pressure treated or Trex might prolong the life ? The upgrade to the mounts is a 'while I am in there' job.
When it runs you can feel the vibration through the thin concrete it sits on.Eventually it will crack. There are mounts made for heavy machinery:
http://www.unisorb.com/products/prod/levline.html
But they are expensive.In the best traditions of G.J. I was trying for an elegant but frugal Rube Goldberg!
T
tonycastec
Los Angeles
For Example,I am thinking of using 4 mounts intended for a Cummins diesel engine(that uses 2). Total weight of the Quincy is less than the 5.9 Cummins turbo diesel-but would have double the mounts -so that 'should 'be O.K.
zcar751
Knoxville, TN
Rubber mounts would work better than hocky pucks and hydralic mounts would be that much better. Those are some of the basic noise deadening step for machinery in industry today.
rsanter
visalia ca
They make rubber mounted feet for machines. That is ideally what you want and they bolt right on. All the rest of the stuff we do here is to save a few bucks
Bob
Flexia
Akron/Canton Ohio
Find some old lawn tires and wheels. Snd weld the compressor to the rim sideways and then inflate the tire with air. You will have yourself a nice airbag that it will sit on.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
There's a multitude of different things you can use, but no reason to spend a large amount of money to mount it. If it's on a concrete floor, something as simple as a rubber floormat cut up works just great. Four pieces of an old tire, a stall mat, anything like that. I have regular isolation pads that I got from the shop they threw out. All they are is a piece of OSB with a honeycomb looking piece of rubber on both sides. The total thickness is maybe 3/8"- 1/2" thick.
Falcon67
Merkel, TX
Best think I've found is stall blanket material from Tractor Supply. High density rubber. Cut a big square, slide it under the compressor - done. My 60 gallon upright sat on three pieces 4" square for 4 years and never moved a millimeter.
T
tonycastec
Los Angeles
Interesting. I have read this suggestion on G.J. previously but I live in an urban area -no Tractor Supply for miles. I might try to find it online.
Is this the correct material:
http://www.tractorsupply.com/webapp...ory_rn=&top_category=&urlLangId=&cm_vc=-10005
Charles (in GA)
50 mi south of Atlanta
MSC has reasonably priced machinery feet.
THESE are what I used, about $20 each
Zrexxer
Pflugerville, TX
You're not going to be able to buy horse stall mat online, those sheets weigh about a hundred pounds each.
My Champion sits on these, found them at Home Depot.
floyd
MD
I bough the same ones as Zrexxer.
ssentt
Iowa
Thats what I have, horse stall mat... 3/4" thick and never had any issues with it. :thumbup:
T
tonycastec
Los Angeles
For a big,clunky, old compressor like the Quincy, it needs super heavy duty feet because of the weight and vibration. It is probably double the weight of the modern compressors shown in the photos. My engine crane really groaned when lifting it off the trailer.
A great thread though & I hope it helps others who follow -if the Search function will find it!
koditten
Midland, Michigan
What are you doing that requires that much vibration absorbence? micro surgery? Just use some 4 x 4 wood blocks. Cheap, easy and usually on hand. Plus you can lag bolt some castors to the blocks if you want move the compressor.
All listed above are great, but really not needed. If that compressor moves with the use of blocks, you got bigger problems.
KO
thatmaskedman
idaho and south
You might want to go to a concrete slab under it. I'm assuming it's on a wood floor. Nothing like dead weight under the mounts to isolate sound/vibration. I worked under a 7.5 DeVilbiss, mounted on a plywood floor. Sounded like someone going at it with a air hammer on a base drum. Sheer torture.
Cryptic1911
Willimantic, CT
They make vibration isolators just for this.. it's a metal box with springs in it, and you mount the compressor to the springs so that they are decoupled from the floor
toomany
Auburn, Mi
KO
x2
I reused the pallet my compressor came on. Simply cut it down and re-bolted it. Hasn't moved at all in the last 5 years. I don't notice any vibrations either. As an added bonus it gets it up higher so I can get at the drain easier.
lametec
I used 3 of these:
They're engine mounts for a Sea-Doo PWC. I bought mine used off ebay, $10 for 4 of them.
Alta_Racer
Red Deer AB Canada
I used the rubber wheels for a boat trailer. (the ones the boat rolls on) Got them cheap at Princess Auto, but any marine supply should have them. Easier than hockey pucks, they had the hole already! Not as hard as a puck, but firmer than rubber. 2 years later, not a mark on them. 60 gal 5hp single stage 3 cyl.
