Burgerkong
I'm going over to pick it up, seller wants $225, probably could get it down to $180-ish. Looks like it has been spray bombed in the past. What are some things I should look out for? Don't have a borescope, so can't peek inside the tank, but will undo the drain and see what color of liquid comes out and stick my finger in there to see if there's any rust. It claims to have a 5hp motor, I've read somewhere that 5hp is definitely possible on 220V. Good buy? I've been looking out for a medium sized compressor (due to space constraints in the garage) for a while and decided on compressors in the 30-40 gal range (Puma makes a 40gal one, but can't get that locally), was going to settle on a cast iron USA-made Husky (which should be identical to the older 30gal Kobalt, IR Garage Mate and the other variants Northern Tool sells).
Thoughts?
Thoughts?
