roto vs flex
blackz26
Byesville, Ohio
I don't like non locking flex head ratchets. But I used my new gear wrench 1/4 ratchet Roto head ratchet today and love it. Seems to me they essentially do the same job with the exception the roto can be used as a driver and is a bit more bulkier. I plan on buy the 3/8 and 1/2 soon enough.
Am i right to say they essentially do the same job?
jmm
NC
Well, there are the obvious design differences: use a roto rat like a screwdriver and a flex like a speeder. I like flexes because they lock (I buy the ones that do, rather). I can crank down a lot harder on them. Rotos I don't lean as much on; they feel a bit more precarious under heavy load. I value my knuckles.
blackz26
Byesville, Ohio
See to me its easier to use a Roto as a speeder. Granted I wouldn't crank on one even with a 1/2. And I still love my telescopic locking flex Stanley.
ilovevocs
Toledo, Ohio
I too would like to hear some real world feedback on the subject. I have been skeptical of the roto ratchets as at first I felt that they were more of a gimmick. The more I look at them the more I think about buying one though.
tjmonsen5
Crystal Lake IL
This might be miniscule, but it seems the socket would be less likely to strip off of a bolt since on a roto head, the axis is directly in the center of the bolt.
On a flex head, the torque comes from the side of the bolt.
I use flex heads.
Rickster
SE PA
My Roto-head ratchets are always my first choice. If you can swing the price pick up the Snap-on 1/4dr and 3/8dr ratchets. I also have the SK 3/8dr roto head and it's a solid ratchet I'd recommend too.
t1r2u3s4t
roto is a better speeder for sure, but roto head tends to be wider and might not fit where a flex head would.
blackz26
Byesville, Ohio
Sorry im anti snap on, not just because of price. I'll probably be going for gear wrench. Good price good ratchet and easy to warranty.
Hiball
Missery
That SK is the best Roto I've ever owned... :rocker:
ddo
Richland
I use both. Tight quarters flex is generally what i reach for. Open spaces, the rotator is my preference. Locking rotator like zyklops is best as a speeder as it stays straight. Zyklops also has a sleeve on shaft and extensions that makes using it as a speeder smooth.
As far as flex wanting to come off bolt more at angles, i dont buy it. Only thing that matters is the point where you apply force relative to position of the head of ratchet. That doesnt change much between flex and roto.
blackz26
Byesville, Ohio
I wish the gear wrench ones had a hold in the the handle so you could slide a little bar in it to make it a ratcheting t handle. I think its kinda funny I don't like non lock flex heads but love my non lock Roto. Just easier for me to keep the handle where I want it. I used the kobalt one in the hot deals for 15 seconds doing a spark plug job and switch ratchets immediately. Gave it to my brother. My locking flex stanely telescopic one, love it.
diesel research
gulf coast, TEXAS
no.
even assuming both heads fit, different tasks require different flexing mechanisms. been in plenty of situations where a roto wouldnt flex right for a needed task. brackets in the way, roto wont flex far enough to bend around bracket w/o smacking into something else.
gotta have them both.
blackz26
Byesville, Ohio
no.
Darn. A reason to buy more stuff.. how will I ever deal....:scared:
