Excellent, looking forward to seeing what you do in there.
Plan is for it to be like yours. Clean, bright, simple, uncluttered.
What did you use for the base material for your side entrance and in the shop before concrete.
The main base for the shop was what my excavator called item 4. Machine tamped. The front incoming drive is crusher run also machine tamped. The side/back drive is just all the top soil from the shop site. It will settle a bit but it;s not for heavy/daily use.
I was always told the concrete shouldn't touch wood when putting up walls on a slab with out that paper foam stuff between the two?
