DARKSCOPE001
Hey guys. at work this past Wednesday I was doing a fuel tank pressure leak check.
This test involves pressurizing the fuel tank of the aircraft (Emberaer 170) to a pressure of 2.5psig then the tank must hold a steady pressure for 10min
Well I was doing the left wing and the fuel tank keept leaking out. So i was using a spray bottle with soap and water to spray all possible sources of leaks. And It was taking me quite a while and I couldnt find any.
My lead tech started getting mad and asking where it was leaking from and I had to hold back from saying "I dont know dumb@$$ if i did do you think i would still be up here doing this test?"
so he proceded to tell me there was a problem with the leak testing box and that I was wasting his time by trying to pressurize the tank with a bad leak test box and that it was my fault. So i went and got a new leak test box and still leaking. So we tried the right hand wing and it worked just fine.
Does anyone else see the problem with this kind of pressure in a work environment? or is this normal. because it was really ticking me off
